Rysowanie 2D
Scale - Tuesday Tips
Przez Rose Barfield 5 min 18 stycznia 2021
If you need to change the size of entities in a drawing, BricsCAD® gives you a few different options: SCALE, The Manipulator, ALIGN and during block insertion.
The SCALE Command
The most familiar way of scaling entities in a drawing is probably the SCALE  command.
SCALE resizes a given selection of entities in relation to a base point. You can enter the scale factor with the mouse, enter a value manually into the Command line or with a reference.
How to use the SCALE command with a manually typed value:
  1. Enter SCALE (SC) into the Command line
  2. Select entities to scale and hit Enter.
  3. Set a base point
  4. Enter a number for the scale factor.
    2 equals 2 times the size, 0.5 equals ½ size.
Scale - Tuesday Tips- scale number
Scaling an entity using a base or reference scale
  3. Set a base point.
  4. Choose the Reference option.
  5. Click to set the first and second points. This is the base scale. The selected entity/entities will now scale dynamically with the mouse.
  6. Click point 3. The entity/entities will now be scaled so that the distance between the 1st and 2nd points is the same as the distance between the first 1st and 3rd points. (See animation below.)
Scale - Tuesday Tips- scale ref
The Manipulator
You can also use The Manipulator to scale entities on a drawing. Just set the arrowhead behavior to Scale. The selected entity/entities will scale from The Manipulator's basepoint.
How to scale objects with The Manipulator:
  1. Set the behavior of The Manipulator arrowheads to Scale. (Mirror is the default behavior for the arrowheads.)
    1. Right-click on the arrowhead. This will open the right-click menu
    2. Navigate to 'Arrowhead acts as' -- '3D Mirror'
    3. Change to 'Arrowhead acts as' -- '3D Scale'.Scale - Tuesday Tips- manipulator-585x413
  2. With the entity/entities selected, launch the Manipulator.
  3. Click the arrow and drag the mouse to resize.
  4. Click to accept the new size.
Align
You might not know it, but you can also scale objects with the ALIGN  command. It works in a similar way to the SCALE command, Reference option. However, as an added bonus, the ALIGN command also moves your entity/entities into alignment with the select points.
How to scale objects with ALIGN
  1. Enter ALIGN.
  2. Select the entity/entities to scale. Hit Enter.
  3. Click the first point on the entity/entities you wish to scale.
  4. Click the first point target location.
  5. Click the second point on the entity/entities you wish to scale.
  6. Click the second point target location.
  7. (Optional) Click the third point on the entity/entities you wish to scale.
    OR
    Hit Enter
  8. (Optional) Click the third point target location.
  9. When asked "Scale entities based on alignment points", choose Yes.
The object will now be scaled and aligned with the target location.
Scale - Tuesday Tips- align
How to Scale Blocks (Non-Uniformally)
You can scale blocks and Xrefs during insertion, even at non-uniform scales.
  1. Enter INSERT.
  2. Click the Browse button.Scale - Tuesday Tips- insert block-585x414
  3. Select the .dwg file for your block.
  4. Specify the scale in the Scale fields.
  5. Click OK.
  6. Click anywhere on the drawing to insert your block.
    Scale - Tuesday Tips- non-uniform scale-768x538
Left: block inserted at 2:3 scale. Right: same block inserted at 1:1 scale
Anything to add?
Do you use any other methods to scale your entities in BricsCAD? Share your tips in the comments section.
Download BricsCAD Shape free
Get BricsCAD free for 30-days
Permanent or subscription licenses that work in all languages, in all regions.
More Tips:
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
