2D Drafting
The Structure Browser - Tuesday Tips
By Rose Barfield 4 min 1 mars 2021
The structure browser displays the entities in the current project as an interactive tree based on properties. This includes the entities contained within any Xrefs. You can change the configuration so that the various elements are organized based on the property that best suits your needs.
How do I access the Structure Browser?
Hover your cursor over a toolbar or the Ribbon, and right-click. Then choose Structure from the drop-down menu or simply enter STRUCTUREPANEL into the Command line.
The icon for the Structure Browser panel is a rectangle with two rectangles beneath it, connected via straight lines:
The Structure Browser - Tuesday Tips- icon
How do I change the configuration of the Structure Browser?
The Structure Browser - Tuesday Tips- configuration 1-01-585x412
Click on the horizontal stripes and select your chosen configuration from the dropdown menu. BricsCAD comes with 3, ready-made configurations: bim, default and mechanical, but you can also add your own.
The Structure Browser - Tuesday Tips- bim mechanical defualt
The same drawing, shown with various configurations of the BricsCAD Structure Browser. Right to left: bim, default, mechanical.
The default sort order is:
default: Layer, Entity type
BIM: Building, Storey, BimType
mechanical: Entity type, Layer, Color
However, if the default configurations don't cut it for you, you can open up the configuration dialog (select it from the drop-down menu). From here you can change the configuration to your heart's content. Our Help Center has detailed instructions on how to change the configuration.
The Structure Browser - Tuesday Tips- drop down menu
The Structure Browser - Tuesday Tips- configure dialog
NOTE: It's a good idea to save a new configuration before making edits to the current configuration. This way you do not lose the BricsCAD default configurations. To do this first click on "File" then select "Save As..." from the drop-down menu.
The Structure Browser - Tuesday Tips- save as
The configuration is saved as a .cst file. By default, the .cst files are stored in the Support Folder.
See the Structure Browser configurator in action →
Did You Know?
You can select objects by clicking on them in the structure panel. Alternatively, right-click to bring up a context menu. This gives you the option to Show, Hide, Isolate and Zoom to the entity/entities selected. Which can be extremely handy when working on large and complicated projects!
Download BricsCAD Shape free
Get BricsCAD free for 30-days
Permanent or subscription licenses that work in all languages, in all regions.
More Tips:
15 april 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 april 2024 4 min
In V24.2, we've further enhanced BricsCAD's DWG compatibility to ensure the rapid creation of design documentation by focusing on the 2D drawing creation workflow. To create the smoothest collaboration, we've ensured you can open and edit the drawings you create in BricsCAD in other DWG-based CAD programs. Let's dive into the enhancements we've made!
25 mars 2024 4 min
Follow us on social media
