Rysowanie 2D
5 Things You Didn't Know You Could Do With the BricsCAD Cursor
Przez Rose Barfield 5 min 24 sierpnia 2020
Ready to test your BricsCAD IQ and see how many of these BricsCAD cursor functionalities you already know? Whether you're a newbie or a BricsCAD veteran, there's always something new to learn and new functionalities to unlock!
5 Things You Didn't Know You Could Do With the BricsCAD Cursor:
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- size
1 Change the crosshair size
Ever wish you had a bigger cursor? In BricsCAD it's easy to make the cursor bigger (or smaller). Enter CursorSize or open the settings and change the value of 'Crosshairs size' to whatever you like.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- color-e1597732951402
The UCS icon and the BricsCAD cursor with new, Hello Kitty inspired, color scheme
2 Change the crosshair color
If you're not a fan of the red, blue, and green systems, or you're colorblind and can't tell the difference, you can change the axis color to anything you like!
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- axis color
The settings for the axis color
Simply enter the settings menu and change the axis color(s) as required.
Note: this also changes the colors of the UCS icon.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- isometric all
Snap Isometric pair (left to right): let, top right
3 Make the cursor isometric
Technically this isn't a cursor mod, although it does change the way the cursor looks!
I cursor crosshair will change to isometric when you turn isometric snapping on. Open the settings and change 'Snap style' to 'Isometric snap'.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- isometric 2-e1597733335954
Isometric snap changes the grid, snap distance, and crosshair cursor to the current isometric plane. It also adds the Isocircle option to the Ellipse command.
Isometric snapping works when ORTHO is switched 'on'
You can choose between Left, Top, and Right isometric pair snaping.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- isometric-e1597733352780
This snap mode also works on temporary snap tracking.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- temp isometric-tracking
Isometric snap tracking also works on temporary snap tracking.
Note: in 3D view, this does not affect the way the cursor looks.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- hover all
Top left: stippled line (default). Bottom left: different color. Top right: thickened line. Bottom right: color and thickness.
4 Change the way the entity highlights on hover
If you have trouble seeing your cursor when you hover over an entity or trouble seeing which part of an entity is selected during a hover, you can change the way the entity looks when you hover the cursor over the entity.
Simply enter Settings and choose between stippled line (default), different color, thickened line and color, and thickness.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor-hover
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- rollovertips 2
5 Rollover Tips
If you're not already using Rollover tips yet, why not? It puts entity information right under your cursor and allows you to change properties, such as a layer, without going through panels.
You can also customize your Rollover Tips, so it shows only the information you need!
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- custom rollover
Customized Rollover tips
If you don't like Rollerove Tips, you can turn it off. Access it in the Status bar (bottom right corner) under 'RT', enter RolloverTips into the Command line and change the value to 0, or turn it "off" via the Settings menu.
Rollover tips BricsCAD cursor settings
Revert back to defaults
So you've messed around with the cursor and you want to get back to how things were originally?
The good news is that this is an easy fix. Simply right-click the setting and select 'Restore default value'. Any settings that have been changed from default display as blue.
5 Things You Didn-t Know You Could Do With the BricsCAD Cursor- restore
Restoring the default value of the cursor in BricsCAD Settings.
Download BricsCAD Shape free
Get started with BricsCAD today
Permanent or subscription licenses that work in all languages, and all regions.
More Tips:
Explore BricsCAD
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
