2D schetsen
Custom Keyboard Shortcuts in BricsCAD - Tuesday Tips
Door Rose Barfield 3 min 24 mei 2021
Custom Keyboard Shortcuts - Tuesday Tips
As I'm sure you're already aware, BricsCAD has a selection of standard keyboard shortcuts. However, you might also want to create your own to launch a command, change the view, or open up a dialog. The good news is that, in BricsCAD, you can!
How to create a keyboard shortcut in BricsCAD
This example will show you how to create a keyboard shortcut (e.g., Ctrl+Alt+E) to launch the Drawing Explorer:
  1. Open the Customize dialog -- enter CUSTOMIZE.
  2. Select the Keyboard tab.
  3. In the left panel, select the customization group file to which you will add this shortcut. You can add it to the leading 'BRICSCAD' customization group or one of your partial menus.Custom Keyboard Shortcuts - Tuesday Tips-1
  4. Right-click and select 'Insert shortcut' ('Append shortcut' if you right-click on the CUI).Custom Keyboard Shortcuts - Tuesday Tips-2
  5. The 'Add keyboard shortcut' dialog opens.
  6. Check the 'Select available tool' option.
  7. In the tree list below, select the Drawing Explorer tool (located under Available tools > BRICSCAD > Drawing Explorer).Custom Keyboard Shortcuts - Tuesday Tips- 3
  8. Click the OK button to close and the 'Add keyboard shortcut' dialog and return to the Customize dialog.
  9. In the Properties grid of the new shortcut, select the Key field, then hit the key combination you want to assign to the shortcut, e.g., Ctrl+Alt+E.Custom Keyboard Shortcuts - Tuesday Tips- 4
  10. Click OK
  11. Test out your new shortcut.
Explore BricsCAD
More Tips:
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
