3D Modellierung
Split Views with Viewports - Tuesday Tips
Von Rose Barfield 4 min 20. Juli 2020
You might be surprised to learn that, in BricsCAD®, you can split the Model Space drawing view into two or more viewports. This allows you to see the same drawing in several different ways, for example, zoomed-in, from a different angle, with a different View style and even, with different visible layers.
How to split the view in your workspace
The create a split view in BricsCAD:
  1. Use the VPORTS  command or locate the Viewports button under the View tab of the Ribbon.
  2. Choose Create 2 viewports, Create 3 viewports or Create 4 viewports.
  3. Choose Horizontal, Vertical, Above, Below, Left or Right.
    Note: options vary based on the number of viewports selected in step 2.
The active viewport is surrounded by a heavy line. To change the active viewport, simply click the viewport you wish to make the active viewport or use the Ctrl+R shortcut to cycle between viewports.
Split Views with Viewports - Tuesday Tips- multi view
Change the view angle
Each viewport can have a different view angle. Control your view angles as you would a single viewport. Use the mouse or the LookFrom widget to change the view in the current viewport.
Want to split the workspace into more than 4 viewports?
No problem! You can split a viewport into yet more viewports.
  1. Select the viewport to split.
  2. Use the VPORTS  command.
  3. Select Create 2 viewports, Create 3 viewports or Create 4 viewports.
Split Views with Viewports - Tuesday Tips- join split
You can also merge viewports.
  1. Enter the VPORTS  command.
  2. Enter Join(J).
  3. Click to select the viewport you want to merge with the active viewport.
Change the visual style
You can change each viewport to a different visual style. You can even set different options in each viewport; Grid view, Layer view, etc.
Split Views with Viewports - Tuesday Tips- view style
Switch between viewport mid-command
You can move from one viewport to another mid-command. Simply click the other viewport (to set it as the active viewport) then continue the command. You can switch as many times as you need to.Split Views with Viewports - Tuesday Tips- switch
Save a viewport layout
To save a viewport:
  2. Enter Save(S).
  3. Choose a name for your viewport.
To load a saved viewport:
  2. Enter Restore(R).
  3. Type the name of the viewport to restore to.
Note: the viewport layout is only saved for the current drawing.
Revert to a single viewport
If you've had enough of split views you can quickly revert to a single view:
  2. Enter Single(SI) -- and you're back to one, single view of your model.Split Views with Viewports - Tuesday Tips- single
Alternatively, choose the Toggle option to temporarily, make the active viewport the only view.
More Tuesday Tips:
19. März 2024 8 min
Neu in BricsCAD® V24.2
BricsCAD® V24.2 verfügt über viele neue und verbesserte Funktionen für 2D-Zeichnung, 3D-Modellierung, Civil, Vermessung, BIM und Mechanical Arbeitsabläufe. Das Bricsys-Team hat in diese Version mehrere neue Funktionen und Verbesserungen integriert, die Ihnen dabei helfen, die Lieferzeit zu verkürzen und Ihnen ein vertrautes CAD-Erlebnis bieten. Beginnen wir also mit der Erkundung der Neuerungen in BricsCAD V24.2!
10. März 2024 6 min
Der Weg zur Scan-to-BIM-Automatisierung mit BricsCAD® BIM V24
Die neuen Automatisierungstools in BricsCAD® BIM V24 machen den Scan-to-BIM-Prozess einfacher und effizienter! Wenn Sie eine schnelle und genaue Realitätserfassung vorhandener Objekte wünschen, sind diese Tools eine großartige Ergänzung Ihres Arsenals. Wir haben Tools wie den Punktwolken-Klassifikator, Punktewolke Räume erkennen, Punktwolke Räume anpassen und Normalen Berechnung für strukturierte Punktwolken hinzugefügt, die Sie bei der Erstellung digitaler Zwillinge für die Mengenabnahme, die Erstellung präziser Gebäudepläne und das Gebäudemanagement unterstützen.
Folgen Sie uns in den sozialen Netzwerken
