2D schetsen
Lineweights in BricsCAD - Tuesday Tips
Door Rose Barfield 3 min 29 juni 2020
For some people, lineweights can seem a little tricky, but in BricsCAD it's really very simple to edit and manipulate lineweight.
Lineweights in BricsCAD - Tuesday Tips- with without lineweight
Left: Drawing with lineweight not displayed. Right: Drawing with linewieght displayed.
How to display lineweights in a drawing in BricsCAD
You can find the control to toggle lineweight display on and off in the bottom-right corner of the BricsCAD interface labeled "LWT". Simply click the letters LWT to toggle it on and off.
Lineweights in BricsCAD - Tuesday Tips- LWT
Click the letter LWT to turn the lineweight view on and off
How to change an entity lineweight in BricsCAD
You can change an entity lineweight using the Properties panel, simply select the entity/entities and then choose the new lineweight from the drop-down menu.Lineweights in BricsCAD - Tuesday Tips- properties Alternatively, you can set all entities to a lineweight by layer.
How to set lineweight by layer
  1. Ensure that all entities are on the correct layer and that lineweight (in the Properties panel) is set to "By layer".
  2. Ensure that lineweight display is "on".
  3. Open the layers panel and choose your preferred lineweight from the drop-down menu. All entities on that layer should now display with the new line weight.
Lineweights in BricsCAD - Tuesday Tips- layer-1024x527
How to set the lineweight for future entities
You have three options to set the line weight for future entities:
  1. Use the properties panel. First, make sure that nothing is selected. Then select the preferred lineweight from the drop-down menu. All future entities will be drawn with this lineweight until otherwise specified.
  2. Alternatively, you can set the lineweight for future entities using the settings dialog. Use the "Entity Lineweight" setting.
  3. To change the default lineweight for BricsCAD use the "Default Lineweight" setting.
    The fastest way to get there is to simply type "LWeight" into the Command line.Lineweights in BricsCAD - Tuesday Tips- line weight settings-585x471
Note: The option "Lineweight Display Scale" only affects model space.
Customizing Linetypes
Now you've got the hang of linewieghts, you might want to start playng with linetypes. Head over to our Customizing BricsCAD blog post on linetypes to learn more.
More Tuesday Tips:
Explore BricsCAD
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
