2D schetsen 3D Modelleren
Tuesday Tips - 'api-ms-win-crt-runtime-dll' Error while starting BricsCAD
Door Rakesh Rao 3 min 14 oktober 2019
When you start BricsCAD software on legacy operating systems, you may run into the 'api-ms-win-crt-runtime-dll' error. By legacy operating systems, I mean Windows 7 or maybe 8, and likely that it is a 32-bit OS, and even likelier that the user may have turned off automatic updates and the Windows has never received the latest patches and updates.
Please be aware that this is a generic problem with all software that requires the VC++ redistributables and not limited to BricsCAD only.
The first thing you can do is to sync your Windows with the latest updates.
To Install Windows updates:
  1. Go to Start > Control Panel > Windows Updates.
  2. Check for updates.
  3. Install all available updates.
  4. After the updates are installed, restart your computer.
  5. After restarting, repeat the steps above again until no more updates are available.
If, for some reason, if you want to skip the above steps, you still have a chance. You can install the Visual C++ re-distributable. If this is missing, you would get the above error.
Even if you have installed Windows updates, do this step explained here.
Installing Visual C++ redistributables:
32-bit download of Visual C++ re-distributable (Windows)
64-bit download of Visual C++ re-distributable (Windows)
Applying either or both of the above fixes should help you to resolve the problem and BricsCAD will start correctly after this.
You can see a detailed explanation and step-by-step solution to this problem from another external site.
How to fix the missing DLL error?
More Tuesday Tips:
api -ms-win- crt -runtime- dll Error while starting BricsCAD was originally published on rakeshrao.typepad.com 27 September and has been edited.
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
