3D Modelleren
Tuesday Tips - Save time with Propagate
Door Rose Barfield 3 min 13 mei 2019
BIM PROPAGATE
Don't waste time repositioning objects around a drawing, duplicating structural elements, or only drafting some areas of a model in detail. Use Propagate (BIMPROPAGATE) to model once and propagate throughout the rest of the model saving you valuable time. It even automatically creates block definitions!
Tuesday Tips - Save time with Propagate- propagate metal
What?
Propagate automatically duplicates:
  • Objects along edges
  • Planar elements
  • Connections
  • Element: beams, brackets, holes, windows: etc
  • Corners
  • And more!Tuesday Tips - Save time with Propagate- PropagateCommands
How?
  1. Start by selecting the solid(s) to which the detail is attached, then launch Propagate.
  2. Select any detail that you wish and hit Enter. A box will appear around the element.
  3. Propagate will then detect the target locations within the model where the same detail can be applied. It automatically rotates and translates the duplicated detail and also makes local changes to solids at the target location to accommodate the detail. For example, Propagate can shorten structural elements and cut holes in them for bolts.
You can go also go into the tool options and modify the arrangements suggested to you. You can use grids to help Propagate intelligently detect advantageous positions. Place an object at a point on a grid and it will automatically detect all other, possible locations.
Tuesday Tips - Save time with Propagate- grid
This extract was taken from a demo at the Bricsys 2019 conference, watch the extended version.
It offers you a range of layouts to choose from, such as different orientations of the details or the choice between similar locations and grid patterns. You can accept or reject the suggested placements with the green tick and red cross icons. An exclamation point will appear if the duplication intersects another object.
Why?
When modeling in typical BIM software you normally model some areas in a high level of detail and forget about other, similar areas. With Propagate you can model complex junctions once and simply hit Propagate to duplicate the junction in all possible areas. This means that the whole model has all the detail. A true digital twin!
Sometimes, for example with supporting columns or brackets, you need to replicate an item. Sure, you can use array or copy, but with Propagate you can use BricsCAD machine intelligence to replicate these across an entire drawing, saving you time.
If you're interested in learning more about Propagate you can meet the developers that created it.
Ready to use Propagate?
Easy to try, easy to buy, easy to own. That's BricsCAD. Download free for 30 days at www.bricsys.com. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with the BricsCAD product family.
More Tuesday Tips:
15 april 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
25 maart 2024 4 min
Volg ons op sociale media
