2D kreslení
Dynamic block editing with Dynamic Grips - Tuesday Tips
Podle Kelsey Grant 3 min 11. října 2021
If you come from an AutoCAD® design environment, you may be familiar with Dynamic Blocks. BricsCAD offers some Dynamic block editing capabilities with Dynamic Grips. Read on to see what you can do with Dynamic Grips in BricsCAD.
1) Flip Grip
Flip Grip allows you to flip a dynamic block on both the horizontal and the vertical axis very simply.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Flip-Grip-1
Dynamic block editing with Dynamic Grips - Tuesday Tips- Flip-Grip-2-1
2) Rotate Grip
Here you can see the Rotate Grip in action, moving this table and chairs block to the desired angle.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Rotate-Grip-1
3) Visibility Grip
The Visibility Grip allows you to choose your desired block, and also which perspective you would like to view it from. Here you can see a car block with a variety of model and perspective options.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Visibility-Grip-1
4) Stretch Grip
With one click you can stretch a dynamic block to your desired dimensions. This stretching is done in incremental lengths defined in your dynamic block.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Stretch-Grip-1
5) Stretch Grip & Array
The stretch grip also works in combination with the Array tool and can be seen in action below. As the table block is lengthened using the Stretch Grip, the chairs array alongside it, saving you time and effort.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Stretch-Grip-Array-1
6) Lookup Grip
Using the Lookup Grip makes adjusting the size of your dynamic block quick and easy. Below you can see the Grip being used to change the size of a table and chairs block.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Lookup-Grip-1
7) Block Table Grip
This Grip is useful when working with dynamic blocks like windows, as in the video below. You can swiftly change the size of your block with minimal disruption to your workflow.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Block-Table-Grip-2
8) Scale Grip
The Scale Grip works on dynamic blocks to increase their size whilst keeping the correct scale, in increments. You can see this taking place on a round table and chairs block in the clip below.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Scale-Grip
You've now seen the most commonly used Grip functions when working with Dynamic Blocks in BricsCAD. You'll be up to speed and at full productivity in no time at all when switching from other CAD software to BricsCAD. Grip features and other handy BricsCAD features will help you along the way!
Take a look at the full video.
Try BricsCAD Free
Get BricsCAD free for 30-days
Permanent or subscription licenses that work in all languages, in all regions.
More Tips:
19. března 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10. března 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Sledujte nás na sociálních médiích
