Modelowanie 3D
BricsCAD Shape Materials - Joachim's Journey - Part 8
Przez Joachim Corijn 2 min 17 października 2019
In the last stop of our BricsCAD Shape Journey, we looked at how to transform entities. During this whistlestop tour, we'll look at how to add materials to your entities in BricsCAD Shape. You'll be surprised how easy it is!
You'll find materials on the right-hand panel in the Icons Strip (it's the paintbrush icon). If you click it the Materials panel will appear.
BricsCAD Shape Materials - Joachim-s Journey -matterials-1024x578
BricsCAD Shape Material types
There are 11 BricsCAD Shape material categories:
  • Earth
  • Fabric
  • Glass
  • Metal
  • Redway (realsitic)
  • Scribbly
  • Solid Colors
  • Stone
  • Tiles
  • Water
  • Wood
Use the search bar to look for an item or navigate via the buttons.
Adding materials to your model
To add a material to your model simply click the material and drag-and-drop.
To assign the material to the entire solid hold Ctrl while dragging and dropping. You can duplicate material assignments by hitting Alt whilst clicking the face of any solid that already has the assigned material.
To assign the same material to multiple entities at the same time, pre-select the entities. Then drag and drop the materials.
BricsCAD Shape Materials - Joachim-s Journey -draganddrop
Drag and drop materials to your model.
Deleting materials
Use the Erase tool to remove materials from an object. It works exactly the same as adding material but in reverse.
What's Next?
I hope you enjoyed this quick guide to the BricsCAD Shape materials. Join me next time when I will be showing you how to use BricsCAD Shape components.
Download BricsCAD Shape Free
Watch the webinar "BricsCAD Shape in 10 minutes"
More CAD lessons:
  1. What is BricsCAD Shape?
  2. Download & Install
  3. Get started
  4. The Interface
  5. Commands
  6. Selecting Objects
  7. Transform
  8. Materials
  9. Components
  10. View Styles
  11. Layers
  12. Editing Entities
  13. More way to Edit Entities
  14. Arrays
  15. Dynamic User Coordinate Systems
  16. Export files and images
  17. Lazy Man's Guide to BricsCAD Shape
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
