Modelowanie 3D
3D Model a Bar of Chocolate - Easy Builds
Przez Rose Barfield 2 min 23 kwietnia 2020
In this series, you will learn how to work with CAD by following easy projects. Use only simple commands to build almost anything! Today, learn how to make a tasty looking 3D model bar of chocolate in BricsCAD®.
Watch the instructional video here
Time to complete: 5-10 minutes
Difficulty: 3/10
Commands used:
Box
Offset
Extrude
Union
Fillet
Scale
Materials
Array Rectangle
How to make a 3D model of a bar of chocolate in BricsCAD:
  1. Begin with the Box command. 10x10x2mm3D Model a Bar of Chocolate - Easy Builds- box-e1587026192237
  2. Offset the top face. 1mm3D Model a Bar of Chocolate - Easy Builds- offset
  3. Extrude at an angle. 3mm 15°3D Model a Bar of Chocolate - Easy Builds- extrude
  4. Union the two solids.3D Model a Bar of Chocolate - Easy Builds- union
  5. Fillet the edges.3D Model a Bar of Chocolate - Easy Builds- fillet-768x491
  6. Copy your logo/design or draw your own with a Polygon or Spline.3D Model a Bar of Chocolate - Easy Builds- logo-768x490
  7. Use the Manipulator to move it into position.3D Model a Bar of Chocolate - Easy Builds- manipulate-1024x478
  8. Scale with the Reference mode.3D Model a Bar of Chocolate - Easy Builds- scale
  9. Extrude down into the block. 1mm3D Model a Bar of Chocolate - Easy Builds- extrude 2-768x514
  10. Delete any remaining 2D entities.
  11. Add Materials.3D Model a Bar of Chocolate - Easy Builds- materials-1024x578
  12. Array with the Rectangle mode. Row = 10, 10mm. Col = 4, 10mm.3D Model a Bar of Chocolate - Easy Builds- array
  13. Edit the Array. Hold Ctrl when hovering over a block and select the command from the Quad, as required.3D Model a Bar of Chocolate - Easy Builds- array edit
  14. Explode the Array.
  15. Union the blocks.
The final result should be a 3D model of a bar of chocolate that looks something like this. Yummy!:
3D Model a Bar of Chocolate - Easy Builds- chcolate-e1587026477728-1024x456
Enjoy this project?
Why not make yourself a rubber duck or a reindeer?
Download BricsCAD free for 30-days
Get started with BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
15 kwietnia 2024 3 min
BricsCAD® Pro V24.2 - Ulepszenia wydajności
BricsCAD V24.2 jest już dostępny, przynosząc ze sobą pakiet ulepszeń wydajności, które obiecują zwiększyć wydajność i stabilność. Najnowsza wersja, dostosowana do potrzeb kreślarzy, projektantów i producentów we wszystkich branżach, koncentruje się na przyspieszeniu tworzenia szczegółowej dokumentacji projektowej niezbędnej do procesów budowlanych, produkcyjnych i produkcyjnych. Przyjrzyjmy się bliżej ulepszeniom w wersji 24.2, które przyspieszą czas oczekiwania na ukończenie.
25 marca 2024 4 min
Śledź nas w mediach społecznościowych
