Modelowanie 3D
What’s new for BricsCAD Shape?
Przez Joachim Corijn 3 min 25 lutego 2019
Bricsys is pleased to announce the release of the latest version of BricsCAD Shape! BricsCAD Shape is our free 3D modeler for everyone. That's right, it's still completely free! This year BricsCAD Shape has been extended to include some new features that make BricsCAD Shape the best free, solid modeling software available. BricsCAD Shape is built on the same platform as BricsCADBricsCAD BIM and BricsCAD Mechanical. So you can learn 3D modeling with BricsCAD Shape and then use the skills you've acquired in Shape to move to BricsCAD BIM.
What's new for BricsCAD Shape?
Quickdraw
What’s new for BricsCAD Shape- quickdraw
Quickdraw your layouts
You've read all about Quickdraw for BricsCAD BIM, well, you can now use Quickdraw in BricsCAD shape! The only difference is that you can't duplicate layouts -- you can only do that in BricsCAD BIM. Quickly draw and create buildings and rooms, as easily as playing a computer game (who doesn't love The Sims?). It snaps to existing wall segments and creates wall connections automatically. Try it, it's super fun.
Materials
What’s new for BricsCAD Shape- matterials
Add materials with drag and drop
Drag-and-drop render materials from the Material Browser onto the desired entity face. Holding CTRL while dropping the material will assign the material to the entire solid. Set a duplicate material by hitting ALT whilst clicking a solid face that already has the assigned material you want. To assign the same material to multiple entities at the same time, pre-select the entities and then, drag and drop the materials.
Components
What’s new for BricsCAD Shape- components
Create your own components with the new and improved components panel
You can now create your own components and add them to your library. Create components from a selection set or whole drawing. Simply click Create component in the Components panel.  It's really that easy. Create it once and use again and again. .dwg drawings that were created with other applications and opened in BricsCAD Shape can also be converted into components. BricsCAD Shape now comes with loads more components as standard, so you might not even need to make your own.
Component categories are no longer displayed in a separate dropdown menu and are now shown as icons on the panel. Plus, components and their category names are now translatable!
Export
You can now export models created in Shape to FBX, STL, DAE, WMF or BMP. Which means that rendering and 3D printing the models you've created with BricsCAD Shape is now a real possibility!
Get started with BricsCAD Shape free
Download BricsCAD shape for free at www.bricsys.com. Start designing today, no subscription, no hidden fees. That's BricsCAD Shape.
All brand names and product names mentioned in this post are trademarks or service marks of their respective companies.
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
