Modelowanie 3D
Dynamic User Coordinate Systems in BricsCAD® Shape - Joachim's Journey Part 15
Przez Joachim Corijn 3 min 24 lutego 2020
This time, we go down-under to the weird and wonderful land of Dynamic User Coordinate Systems (DUCS). This is a really powerful tool that allows you to draw on different planes in BricsCAD Shape. Not just on the "flat" x/y plane but the "vertical" z/y, z/x planes and pretty much any orientation in between.
What are the X Y and Z axes?
Imagine that X is "left and right" and Y "forward and backward" and Z is "up and down".
By default, BricsCAD® Shape draws along the X/Y plane and the 0 point on the Z-axis. Just think about it as though it's a large sheet of paper laid flat on the ground. This determines where you can start drawing a 2D or 3D object.
Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -flat logo-1024x576
Here you can see that the logo is resting flat on the x/y pane "the ground". This is the standard drawing plane for BricsCAD Shape.
How to draw on a different plane in BricsCAD Shape
If you want to draw at a different angle you need to change the UCS (User Coordinate System) -- "move the sheet of paper". The good news is that this is easy to do BricsCAD Shape.
You see this thing?:
Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -UCS
That's the UCSIcon. It basically tells you where the 0,0,0 coordinate is and which direction the x, y and z axes are.
To change the UCS (user coordinate system):
  1. If I have DUCS turned "on" (hit F6 to toggle it on and off)
  2. Execute a command.
  3. Hover over a face that represents the correct plane.
  4. Hit Shift to fix the UCS.
  5. Start drawing, the UCS will remain fixed for the duration of this command.Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -dynamic cube
Did you know?
It doesn't just work on flat surfaces, you can also use it on curves too!
Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -dynamic spher
Curiosity not satisfied? Learn more about UCS.
What's next?
In this CAD lesson, we looked at ways to draw on different planes in BricsCAD Shape. In the next lesson, we'll take a look at ways to export your models.
Download BricsCAD Shape free
Watch the webinar "BricsCAD Shape in 10 minutes"
More CAD lessons:
  1. What is BricsCAD Shape?
  2. Download & Install
  3. Get started
  4. The Interface
  5. Commands
  6. Selecting Objects
  7. Transform
  8. Materials
  9. Components
  10. View Styles
  11. Layers
  12. Editing Entities
  13. More way to Edit Entities
  14. Arrays
  15. Dynamic User Coordinate Systems
  16. Export files and images
  17. Lazy Man's Guide to BricsCAD Shape
15 kwietnia 2024 3 min
BricsCAD® Pro V24.2 - Ulepszenia wydajności
BricsCAD V24.2 jest już dostępny, przynosząc ze sobą pakiet ulepszeń wydajności, które obiecują zwiększyć wydajność i stabilność. Najnowsza wersja, dostosowana do potrzeb kreślarzy, projektantów i producentów we wszystkich branżach, koncentruje się na przyspieszeniu tworzenia szczegółowej dokumentacji projektowej niezbędnej do procesów budowlanych, produkcyjnych i produkcyjnych. Przyjrzyjmy się bliżej ulepszeniom w wersji 24.2, które przyspieszą czas oczekiwania na ukończenie.
25 marca 2024 4 min
Śledź nas w mediach społecznościowych
