3D Modelleren BIM
2D, 3D, BIM - 9: The House P2 - The Roof
Door Rose Barfield 4 min 6 juni 2019
Last time we looked at how to use some of the tools used to create walls, slabs (floors) and simple flat rooves. This time I'm going to show you another way of making a flat roof and one method to create a pitched roof. There are still many, many ways of working with BricsCAD BIM, but this should give you a good starting point.
New Commands covered this time:
This time we will focus on new techniques for commands you already know.
Watch video on YouTube
Flat Roof
I created a flat roof by extruding some of the existing walls, tidying up the join and extruding a floor.
How to do this:
  1. Draw a line across the top.
  2. IMPRINT the line on the top face of the far wall shown (yellow). Delete the source object?: yes.2D, 3D, BIM - 9 The House P2 - The Roof- 1 line orange
  3. Select the top surfaces shown (orange).2D, 3D, BIM - 9 The House P2 - The Roof- 2 select
  4. EXTRUDE up.2D, 3D, BIM - 9 The House P2 - The Roof- 3 extrude-1
  5. Use TCONNECT -- 'Connect to nearest' to close the gap.
    Note: If you are not sure how to do this, check Part 1.2D, 3D, BIM - 9 The House P2 - The Roof- 4 connecttonearest
  6. Draw a RECTANGLE in the gap.
    Note: Use DUCS to align the rectangle with the top face of the lower layer walls.2D, 3D, BIM - 9 The House P2 - The Roof- 6 polyline
  7. EXTRUDE the rectangle up to create a flat roof.2D, 3D, BIM - 9 The House P2 - The Roof- 7 extrude
Sloped Roof
I used a polysolid to create a base for my roof, edited it and then connected the exterior and interior walls to the roof.
How to do this:
  1. Use POLYSOLID to draw a roof.
    Note: Hit Shift to change the UCS.2D, 3D, BIM - 9 The House P2 - The Roof- 9 polysolid
  2. MIRROR the roof.2D, 3D, BIM - 9 The House P2 - The Roof- 10 mirror
  3. Use LCONNECT to join the solids.2D, 3D, BIM - 9 The House P2 - The Roof- 11 lconnect
  4. Use PUSHPULL to set the correct overhang.2D, 3D, BIM - 9 The House P2 - The Roof- 9.5 pushpull
  5. SLICE the walls shown (blue).
    Note: If you are not sure how to do this, check part 5.2D, 3D, BIM - 9 The House P2 - The Roof- slice 1-copy
  6. Repeat2D, 3D, BIM - 9 The House P2 - The Roof- slice 2-copy
  7. Select the top faces of the wall solids (orange).
  8. Connect to Nearest.2D, 3D, BIM - 9 The House P2 - The Roof- conect to nearest
  9. Shorten the overhang of the roof with PUSHPULL.2D, 3D, BIM - 9 The House P2 - The Roof- 15 pushpull
  10. LCONNECT to tidy the join.2D, 3D, BIM - 9 The House P2 - The Roof- 16 lconnect
Finishing up
Use BIMCLASSIFY to assign the appropriate BIM information to the newly created roof: 'BIM Roof'. If you can't remember how, check part 8.
2D, 3D, BIM - 9 The House P2 - The Roof- FINAL2
Next Time
Now it's taking shape! Now the building has a roof. Join us next time when we look at how to windows and doors using BricsCAD BIM.
Don't have BricsCAD yet?
Easy to try, easy to buy, easy to own. That's BricsCAD. Try all of our products, for free for 30 days at www.bricsys.com. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with BricsCAD.
Keep Reading
  1. Moving from 2D to 3D CAD
  2. 3D Drawing from engineering plans
  3. Drawing everything but the kitchen sink
  4. More Advanced Modeling
  5. The Shower
  6. The Sink
  7. The Toilet
  8. Walls and Floors
  9. The Roof
  10. Windows and Doors
  11. Create your own components
  12. Rubber Duck
  13. Laser-cut puzzle project
Note: This series is intended as a guide to demonstrate how to use different aspects of 3D modeling tools. It may not always demonstrate the fastest way of getting the result. Keep coming back to see if we cover a faster technique at a later date.
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
