Quick links:
- Filtered search
- DELETETOOL
- UCSORTHO
- ORBITAUTOTARGET
- MANIPULATOR
- APERTURE
- HIGHLIGHTEFFECT
- USENEWRIBBON
- CMDLNTEXT
- Review Your Custom Settings
1. Filtered search
Did you know you can get the Settings dialog to display only the settings that match your search term? This can save you lots of time when you are looking for a setting but aren’t sure where to find it or precisely what it’s called.
To access this:
- Open the Settings dialog (SETTINGS).
- In the top-left corner, click the Alphabetic option – the second icon.
- Enter a search term, and the Settings dialog will only display settings related to your search term.
2. DELETETOOL
Keep all the entities you're using during the SUBTRACT command. BricsCAD deletes any entities used to subtract by default, but the DELETETOOL system variable allows you to keep them.
How it works:
- In the Settings dialog, untick the DELETETOOL system variable – turn it off.
- Exit the Settings dialog.
- Use the SUBTRACT command as usual.
- The entity/entities used to subtract from the second solid will remain in the drawing.
3. UCSORTHO
Automatically switch the drawing plane to match the view in the current viewport. By default, BricsCAD® draws on the XY plane, but it is possible to change the drawing plane to match the view by switching on the UCSORTHO system variable.
This only works if the view is set with the LookFrom widget (the circle in the top-right of model space) or the VIEW command.
How it works:
- In the Settings dialog, check the UCSORTHO system variable – turn it on.
- Set orthographic view as required. Use either the VIEW command or the LookFrom widget.
- Start drawing.
- Repeat steps 2-3 as required.
4. ORBITAUTOTARGET
Rotate around any entities displayed on the screen or around selected entities. By default, BricsCAD rotates around the point where you first click. Use the ORBITAUTOTARGET system variable to change this behavior.
How it works:
- In the Settings dialog, check the ORBITAUTOTARGET system variable – turn it on.
- (Optional) Select an entity or set of entities.
- Hold Shift, click and hold the middle mouse button, then move the cursor.
- If no entities are selected, the view will rotate around the entities currently displayed.
- If entities are selected, the view will rotate around the selected entity/entities.
5. MANIPULATOR
Set the Manipulator to appear whenever you select an entity. By default, the Manipulator appears if you have at least one entity chosen and hold the left mouse button for an extended time. Use the MANIPULATOR system variable to change this behavior.
How it works:
- In the Settings dialog, change the MANIPULATOR system variable to 1.
- Select an entity or set of entities.
- The Manipulator will appear.
6. APERTURE
Tweak the sensitivity of snapping in BricsCAD. This setting can be conducive if you find the sensitivity too high and BricsCAD is snapping to anything, and everything, or your screen is enormous, and you want to move your mouse less.
How it works:
- In the Settings dialog, change the APERTURE system variable – the default is 10.
- Start drawing as usual and see how the sensitivity works for you. Getting it to work exactly how you want might take a few tries.
- (Optional) To visualize the snap area, turn on the Entity Snap Aperture Box - the APBOX system variable.
7. HIGHLIGHTEFFECT
Change the way selected entities appear in BricsCAD. By default, selected 2D entities appear as a stippled “dotted” line. However, with the HIGHLIGHTEFFECT system variable, it is possible to change this behavior to a different color, a different thickness, or both!
How it works:
- In the Settings dialog, change the HIGHLIGHTEFFECT system variable.
- (Optional) Change the color of the highlight – use the HIGHLIGHTCOLOR system variable.
- Hover over an entity.
8. USENEWRIBBON
In V23, there is a new Beta ribbon (the area at the top of the workspace that shows tools and commands). You can access it with the USENEWRIBBON variable. This will be the default for V24, so we’d love you to test it out and let us know what you think.
How it works:
- In the Settings dialog, check the USENEWRIBBON system variable – turn it on.
- Restart BricsCAD.
- Test out the Ribbon and let us know what you think via a support request.
9. CMDLNTEXT
Want to prank a colleague that just left their workspace unattended? Then this is the system variable for you! By default, BricsCAD’s command line displays a simple “:”, but with the CMDLNTEXT system variable, it is possible to change this to anything you like…
How it works:
- In the Settings dialog, change the CMDLNTEXT system variable – we’ll leave this up to your imagination.
- Your text should now display in the Command line.
10. Review Your Custom Settings
After all this fun, you might have gotten confused about what you’ve changed or want to go back to how things were before. Luckily, a section in the Settings dialog allows you to see all the customized settings.
To access this:
- In the top-left corner, click the Show differences option – the third icon.
- All customized settings will be displayed.
To revert to a setting:
- Right-click the setting.
- Select Restore default value.
Want more BricsCAD tips and tricks?
If you’re curious about what else you can do in BricsCAD, check out our YouTube channel where you can learn more about BricsCAD’s features and commands, or take a peek at the rest of the Bricsys blog.
