2D 製圖 3D 建模
Printing in BricsCAD – Layouts
By Kelsey Grant 3 分鐘 2022年2月21日
When printing in BricsCAD, there are two main interfaces to explore: Model Space and Paper Space. Model Space is a black screen wherein you create your 2D drawings and 3D models. In Paper Space we create layouts and are typically used to organize drawings for hard copy or soft copy printing.
When you open BricsCAD, you can see three tabs at the bottom of the workspace. By default, you will be in the Model Space. You can see the model tab is active and you can switch over to Paper Space by clicking on any of these layout tabs.
BricsCAD Layouts tabs - GIF
Next, you can select the 'Layout 1' tab to switch over to the Paper Space. This white screen is a representation of a sheet of paper where you can see your drawing opened in a viewport.
A viewport is an entity on the layout and is a window to the Model Space. Each layout can have a different paper size and varied properties such as plot style, table drawing orientation,  printer configuration, etc. You can select the right layouts to properly communicate your unique design.
BricsCAD Layouts select - GIF
Let's change the properties of Layout 1. To do this, you'll need to right-click on 'Layout 1' and click on 'Page setup'. In the printer plotter configuration, you will get a pop-up list in which different plotters are listed. Click on 'Print as pdf' to get a pdf soft copy output, and in the paper size popup choose a suitable paper size depending upon your requirements. Here we've clicked on 'iso A3' to plot to an A3 size paper. You can change the units to inches or millimeters. We've selected millimeters and a plot scale of 1:1.
Next, you'll need to click on the plot style table pop-up and choose 'Default.ctb'. Select 'Landscape' to get a landscape drawing orientation, and then select 'OK'.
BricsCAD Layouts style layout - GIF
To finish, you'll click on 'Layout 2', right-click and go to 'Page setup'. Here you can change the parameters of this layout. You can create as many layouts as you want by clicking on the plus sign. To rename a layout, right-click on the layout tab and select the 'Rename' option to give your layout a suitable name.
To delete a layout you'll need to right-click on the layout tab and select the 'Delete' option.
BricsCAD Layouts - delete layout GIF
Now you know the basics of printing, the different layouts in BricsCAD, and how you can use them to navigate and communicate your unique design! If you'd like to know more, you can view the full video.
Learn more about Paper Space in BricsCAD:
2024年3月19日 2 分鐘
BricsCAD® V24.2 的新功能
BricsCAD® V24.2 為2D繪圖、3D建模、土木、測量、BIM 和機械工作流程提供了大量新功能和增強功能。在此版本中,Bricsys 團隊包含了多項新功能和改進,可協助您加快交貨速度並為您提供熟悉的 CAD 體驗。 那麼,讓我們深入探討 BricsCAD V24.2 中的新增功能!
2024年3月10日 2 分鐘
使用 BricsCAD® BIM V24 實現掃描到 BIM 自動化的途徑
BricsCAD ® BIM V24 中包含的新自動化工具讓掃描到 BIM 流程更輕鬆、更有效率!如果您想快速、準確地對現有物件進行現實採集,這些工具將是您的最佳選擇。我們為結構化點雲添加了點雲分類器、點雲偵測房間、點雲擬合房間和法線計算等工具,以協助您創建用於工程量計算的數位對映、創建精確的建築計劃和設施管理。偵測
在社交媒體上關注我們
