Search
2D DraftingCivil & Surveying
Find Outliers in BricsCAD® Pro - Working Smarter with BricsCAD
By The Bricsys Team 3 min 25 พฤษภาคม 2566
We have made it easier to find outliers in BricsCAD Pro V23.2 and enhanced the FINDOUTLIERS command - let's catch you up!
Valid region
This example begins with a land surveying DWG file – the 2D results of a scanned terrain. We want to place all the geometry around the origin to clean up the drawing.
null
Navigate to the Manage Tab in the ribbon and launch the FINDOUTLIERS command.
null
Tip! The tips panel provides you with some handy tips and tricks about how to use the FINDOUTLIERS command.
null
Specify a valid region.
Most of the geometry in this file is far from the valid region around the origin. If needed, change the valid region.
null
Inspecting Outliers
When you are happy with the valid region, you can inspect the outliers.
You can view outliers in the list view, where they are grouped into clusters.
In this example, you can see three clusters of outliers and one individual outlier. The bulk of this model consists of about 13,000 outliers, so you need to move this around the model's origin – which you can do with a single click.
null
Use the move function to move these outliers into the valid region.
Use the zoom function to inspect any remaining individual outliers.
Remove irrelevant outliers as needed.
Move
For this example, you can see a group of geometry relevant to the model, so you need to move it to the origin.
null
You can manually move this geometry to the origin by choosing where to move the objects.
null
Once you are happy with the configuration, you can end the commands.
And that's it – you have centered all geometry around the origin in just a few clicks!
Watch the video!
Check out the YouTube walkthrough to watch the FINDOUTLIERS command in action!
Get started with BricsCAD Pro today!
Buy BricsCAD Pro or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD Pro.
Have you tried the enhanced FINDOUTLIERS command and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to let us know what you think about BricsCAD is to send us a support request; our support team will gladly help.
Want more BricsCAD tips and tricks?
If you're curious about what else you can do in BricsCAD, check out our YouTube channel to learn more about BricsCAD's features and commands or take a peek at the rest of the Bricsys blog.
15 พฤษภาคม 2566 7 min
Artificial Intelligence in BricsCAD® Lite & Pro – What's the Point? Checking drawing health
In the previous blog post, we explained how automation and artificial intelligence are baked into key processes in BricsCAD® BIM to speed up your building design workflows. At Bricsys, we apply similar techniques across our BricsCAD® product portfolio, so we take the same approach with our flagship products BricsCAD® Lite and BricsCAD® Pro.
Follow us on social media
