Management Documente
View 2D & 3D CAD files online with Bricsys 24/7
De Rose Barfield 3 min 15 august 2019
Bricsys 24/7 allows you to view 3D files online, in your browser. Thanks to Bricsys 24/7's built-in 3D viewer, every person working on a project can open, explore, and annotate 3D models whenever they need to, even without CAD software installed on their machine. This includes all BricsCAD native .dwg files.
If you are looking for a way to view .dwg files for free check out BricsCAD ShapeODA's online .dwg converter
CAD file types supported by Brisys 24/7's online viewer:
  • dwg
  • dwf
  • dwfx
  • dxf
  • dgn
  • plt
  • hp
  • hpg
Bricsys 24/7 also provides full IFC (Industry Foundation Classes) support. Learn more about IFC.
Online viewer
You can upload, download, share, and view 3D models from your browser, without installing any software. There is also a direct connection from BricsCAD and BricsCAD BIM to Bricsys 24/7 so now it's even easier to share your files!
View 2D & 3D CAD files online with Bricsys 247- 3D viewer
No experience? No problem!
Bricsys 24/7 online 3D viewer is super easy to use, even with no experience working with CAD programs. Rotate and zoom in and out of the model, all from your browser. Use Bricsys 24/7's native tools to create a slice through the building. You can even add annotations to the models and you have full control over who can see the comments: keep them private, just share with the architect or make them viewable to everyone.
View 2D & 3D CAD files online with Bricsys 247- slice anotate
View BIM files in-browser
If you have projects with vast amounts of BIM data and plenty of associated documents, that's no problem. 24/7's model server manages all of the information required in a construction project.
It's easy to browse through a model's structure. Use the panel on the left-hand side of the screen to isolate an element and access any additional data related to that entity. You can query, merge, and filter the view depending on your individual needs.
View 2D & 3D CAD files online with Bricsys 247- structure
Full external reference file management
In addition, Bricsys 24/7 supports models using external references (XRefs). Bricsys 24/7 will recognize and automatically manage links between files.
XRefs allow a single file to reference other files and are typically used in large projects to keep down file sizes and allow people to work on different parts of a model at the same time. Learn more about XRefs.
More file types
Bricsys 24/7 doesn't just support .dwg and CAD files! It also offers in-browser support for over 70 different file types. Find the complete list of file types supported by Bricsys 24/7.
Ready to share your files online?
Find out more about Bricsys 24/7 at www.bricsys.com. Easy to try, easy to buy, easy to own. That's Bricsys. Try all of our products, for free for 30 days. You'll love what we've built for you with the Bricsys product family.
15 aprilie 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 aprilie 2024 4 min
Compatibilitate îmbunătățită a desenelor în BricsCAD® V24.2
În V24.2, am îmbunătățit și mai mult compatibilitatea DWG a BricsCAD pentru a asigura crearea rapidă a documentației de proiectare, concentrându-ne pe fluxul de lucru pentru crearea desenelor 2D. Pentru a crea cea mai bună colaborare, ne-am asigurat că puteți deschide și edita desenele pe care le creați în BricsCAD în alte programe CAD bazate pe DWG. Haideți să ne aruncăm în îmbunătățirile pe care le-am făcut!
25 martie 2024 4 min
Ce este nou în BricsCAD® Lite și Pro V24.2
În cea mai recentă actualizare, BricsCAD® V24.2 aduce multe caracteristici noi și îmbunătățite pentru a vă îmbunătăți crearea de desene 2D. Am introdus o experiență de utilizare mai intuitivă, am îmbunătățit performanța și stabilitatea și am adăugat funcții noi și îmbunătățite pentru a vă spori și mai mult productivitatea. Această versiune oferă fluxuri de lucru pentru a facilita precizia și versatilitatea de care aveți nevoie pentru ca proiectele de desen și proiectare 2D să se desfășoare fără probleme.
Urmărește-ne pe rețelele sociale
