Desenho 2DModelagem 3D
Printing in BricsCAD – Layouts
Por Kelsey Grant 3 min 21 de fevereiro de 2022
When printing in BricsCAD, there are two main interfaces to explore: Model Space and Paper Space. Model Space is a black screen wherein you create your 2D drawings and 3D models. In Paper Space we create layouts and are typically used to organize drawings for hard copy or soft copy printing.
When you open BricsCAD, you can see three tabs at the bottom of the workspace. By default, you will be in the Model Space. You can see the model tab is active and you can switch over to Paper Space by clicking on any of these layout tabs.
BricsCAD Layouts tabs - GIF
Next, you can select the 'Layout 1' tab to switch over to the Paper Space. This white screen is a representation of a sheet of paper where you can see your drawing opened in a viewport.
A viewport is an entity on the layout and is a window to the Model Space. Each layout can have a different paper size and varied properties such as plot style, table drawing orientation,  printer configuration, etc. You can select the right layouts to properly communicate your unique design.
BricsCAD Layouts select - GIF
Let's change the properties of Layout 1. To do this, you'll need to right-click on 'Layout 1' and click on 'Page setup'. In the printer plotter configuration, you will get a pop-up list in which different plotters are listed. Click on 'Print as pdf' to get a pdf soft copy output, and in the paper size popup choose a suitable paper size depending upon your requirements. Here we've clicked on 'iso A3' to plot to an A3 size paper. You can change the units to inches or millimeters. We've selected millimeters and a plot scale of 1:1.
Next, you'll need to click on the plot style table pop-up and choose 'Default.ctb'. Select 'Landscape' to get a landscape drawing orientation, and then select 'OK'.
BricsCAD Layouts style layout - GIF
To finish, you'll click on 'Layout 2', right-click and go to 'Page setup'. Here you can change the parameters of this layout. You can create as many layouts as you want by clicking on the plus sign. To rename a layout, right-click on the layout tab and select the 'Rename' option to give your layout a suitable name.
To delete a layout you'll need to right-click on the layout tab and select the 'Delete' option.
BricsCAD Layouts - delete layout GIF
Now you know the basics of printing, the different layouts in BricsCAD, and how you can use them to navigate and communicate your unique design! If you'd like to know more, you can view the full video.
Learn more about Paper Space in BricsCAD:
Kelsey Grant - Author
por Kelsey Grant - Marketing Content Specialist
LinkedIn logo (b&w)
Kelsey é nossa especialista em conteúdo de marketing na Bricsys, e tem sua base no Reino Unido. Vindo de uma experiência em Mídia Social para CAD, ela se orgulha de criar conteúdo claro e envolvente, ajudando a orientar os usuários do BricsCAD a criar grandes coisas!
15 de abril de 2024 3 min
BricsCAD® Pro V24.2 - Melhorias de Desempenho
O BricsCAD V24.2 está aqui, trazendo consigo um conjunto de melhorias de desempenho que prometem aumentar a eficiência e a estabilidade. Adaptada para desenhistas, projetistas e fabricantes de todos os setores, a versão mais recente se concentra em acelerar a criação de documentação detalhada de projeto, essencial para os processos na construção, fabricação, e manufatura. Vamos dar uma olhada mais de perto nos aprimoramentos da V24.2 que vão acelerar o seu tempo de entrega.
8 de abril de 2024 4 min
Compatibilidade de Desenho Aprimorada no BricsCAD® V24.2
Na V24.2, aprimoramos ainda mais a compatibilidade DWG do BricsCAD para garantir a rápida criação da documentação do projeto, concentrando-nos no fluxo de trabalho de criação de desenhos 2D. Para criar a colaboração mais suave, garantimos que você possa abrir e editar os desenhos criados no BricsCAD em outros programas CAD baseados em DWG. Vamos nos aprofundar nos aprimoramentos que fizemos!
Siga-nos nas mídias sociais
