Bricsys Digital Summit: BricsCAD V23 Spotlight – How BricsCAD® Mechanical Unites 2D and 3D Capabilities in one CAD Platform
In the BricsCAD V23 Spotlight blog series, we are exploring the themes of the summit and how our four guiding principles helped to shape BricsCAD Version 23’s new features, tools and commands. 
In the previous post on CAD-based innovation, we looked at how Bricsys has promised to deliver the best tools, with AI and machine learning, for users to enjoy drafting, designing and modeling, all on an advanced DWG-based platform.
Here, we review the BricsCAD Mechanical session from the Digital Summit, presented by Gavin England from the Go-to-Market team and Cliff Brown, Executive Product Manager at Bricsys.
They explore the new features for 2D mechanical, 3D assemblies and even more open, compatible workflows. Gavin and Cliff demonstrate how BricsCAD Mechanical offers a uniquely flexible approach to 3D modeling and new capabilities - from fundamental drafting to advanced mechanical design.
Gavin and Cliff - Bricsys Digital Summit
Challenges facing manufacturers
Gavin opened the session by setting out the typical challenges faced by manufacturers today:
  • Shortage of skilled and experienced workers
  • Changing market landscape and volatile supply chains
  • Customer demands – faster product delivery
  • Customers wanting more choice and product personalisation
And how greater agility helps to overcome these challenges.
How can BricsCAD Mechanical V23 help?
With the new features and enhancements, BricsCAD Mechanical V23 gives users greater agility. Gavin went on to outline how.
New 2D mechanical symbols and annotations enable users to create new and modify existing 2D documentation much faster, while 3D assemblies can be built and updated more efficiently and flexibly. For users working on welded-fabrication designs, they can create and detail those more quickly. The increased openness enables users to better address wider workflows more seamlessly.
Plus, the performance improvements like greater compatibility with AutoCAD Mechanical and further integration between the mechanical and BIM worlds, allow faster response to changing environments, demands and needs.
BricsCAD Mechanical in more detail
Cliff then goes into more detail about BricsCAD Mechanical.
“Mechanical is intelligent. The AI enabled automation philosophy you can see with BricsCAD Pro and Lite extend itself here too”
The features within BricsCAD Pro which allow you to automate repetitive tasks, optimize drawings and guide users are all still relevant. But in addition, BricsCAD Mechanical also features unique intelligent capabilities aimed at manufacturers.
Flexible approach to 3D modeling
Our 3D modeling approach is uniquely flexible, where direct and parametric modeling methods sit together. Allowing users to directly manipulate the model and then control any element of it with parameters and constraints, in a hybrid approach.
This makes design creation and modification simple and easy to understand and re-using imported data incredibly easy and fast.
2D and 3D in one single environment
BricsCAD Mechanical provides advanced 3D modeling, sheet metal design and assembly development. However, it also provides the complete set of 2D tools found in BricsCAD Pro and additional 2D mechanical detailing features.
These are all in one single environment - making it easy to design in 2D, 3D, or any combination of the two. This enables a huge amount of flexibility in your workflows.
Accessible mechanical design for everyone
Specialist mechanical design tools are often overly complex and prohibitively expensive. BricsCAD Mechanical is built on BricsCAD Pro, so it has the same familiar look and feel, and native DWG file format.
It eliminates the complexity found in traditional, history-based tools, so there is no need to figure out a new product or spend weeks translating existing DWG data. Nor do you have to learn completely different design techniques.
BricsCAD Mechanical really does make mechanical design accessible for everyone.
To hear more about BricsCAD Mechanical and see the demos, watch the full on-demand session.
Watch more CAD command demos: Bricsys Digital Summit now on-demand
The Bricsys Digital Summit 2022 is now on-demand. Catch up on all the latest innovative tools in BricsCAD V23. See product experts, live demos, break-out sessions and find out how you can Build Better with Bricsys. 
Get started with BricsCAD V23 today!
Why not find out the BricsCAD difference for yourself? Buy BricsCAD or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
Bricsys Icon
The Octave BricsCAD Team
Het Octave BricsCAD Team zet zich in om u praktische tips, tricks, how-to’s en inzichten uit de sector te bieden, zodat u het maximale uit BricsCAD kunt halen.
