3D Modelleren
BricsCAD Shape Materials - Joachim's Journey - Part 8
Door Joachim Corijn 2 min 17 oktober 2019
In the last stop of our BricsCAD Shape Journey, we looked at how to transform entities. During this whistlestop tour, we'll look at how to add materials to your entities in BricsCAD Shape. You'll be surprised how easy it is!
You'll find materials on the right-hand panel in the Icons Strip (it's the paintbrush icon). If you click it the Materials panel will appear.
BricsCAD Shape Materials - Joachim-s Journey -matterials-1024x578
BricsCAD Shape Material types
There are 11 BricsCAD Shape material categories:
  • Earth
  • Fabric
  • Glass
  • Metal
  • Redway (realsitic)
  • Scribbly
  • Solid Colors
  • Stone
  • Tiles
  • Water
  • Wood
Use the search bar to look for an item or navigate via the buttons.
Adding materials to your model
To add a material to your model simply click the material and drag-and-drop.
To assign the material to the entire solid hold Ctrl while dragging and dropping. You can duplicate material assignments by hitting Alt whilst clicking the face of any solid that already has the assigned material.
To assign the same material to multiple entities at the same time, pre-select the entities. Then drag and drop the materials.
BricsCAD Shape Materials - Joachim-s Journey -draganddrop
Drag and drop materials to your model.
Deleting materials
Use the Erase tool to remove materials from an object. It works exactly the same as adding material but in reverse.
What's Next?
I hope you enjoyed this quick guide to the BricsCAD Shape materials. Join me next time when I will be showing you how to use BricsCAD Shape components.
Download BricsCAD Shape Free
Watch the webinar "BricsCAD Shape in 10 minutes"
More CAD lessons:
  1. What is BricsCAD Shape?
  2. Download & Install
  3. Get started
  4. The Interface
  5. Commands
  6. Selecting Objects
  7. Transform
  8. Materials
  9. Components
  10. View Styles
  11. Layers
  12. Editing Entities
  13. More way to Edit Entities
  14. Arrays
  15. Dynamic User Coordinate Systems
  16. Export files and images
  17. Lazy Man's Guide to BricsCAD Shape
15 april 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
25 maart 2024 4 min
Volg ons op sociale media
