Zoeken
Applicaties
40+ Free CAD Block Libraries from Known Manufacturers - CADprofi
Door Karol Klimowicz 4 min 12 augustus 2020
CP-Manufacturers - CAD block libraries from CADprofi - gives you access to more than 40 free CAD libraries from world-known manufacturers. Use them for sanitary, central heating, ventilation, electrical and other types of installations. Some of these libraries are available free, as a stand-alone application and others are included as part of the BricsCAD-CADprofi application.
These libraries are perfect for:
  • Apparatus and electrical switchboards
  • Busbars, mesh cable trays
  • Lighting protection system
  • Armature, pumps, boilers, tanks, etc
  • Elements of exhaust fumes/chimney installations
  • Elements of plumbing installations
  • Typical boiler systems
Electrical Industry Parts Catalogs
40+ Free CAD Block Libraries from Known Manufacturers -abb 40+ Free CAD Block Libraries from Known Manufacturers -hager 40+ Free CAD Block Libraries from Known Manufacturers -legrand 40+ Free CAD Block Libraries from Known Manufacturers -eti
40+ Free CAD Block Libraries from Known Manufacturers -lovato 40+ Free CAD Block Libraries from Known Manufacturers -dehn 40+ Free CAD Block Libraries from Known Manufacturers -trilux 40+ Free CAD Block Libraries from Known Manufacturers -trilux
40+ Free CAD Block Libraries from Known Manufacturers -bkj 40+ Free CAD Block Libraries from Known Manufacturers -elko bis 40+ Free CAD Block Libraries from Known Manufacturers -pulsar 40+ Free CAD Block Libraries from Known Manufacturers -pawbol
40+ Free CAD Block Libraries from Known Manufacturers -tkrem 40+ Free CAD Block Libraries from Known Manufacturers -puk 40+ Free CAD Block Libraries from Known Manufacturers -lamel 40+ Free CAD Block Libraries from Known Manufacturers -bcs
40+ Free CAD Block Libraries from Known Manufacturers -fandf 40+ Free CAD Block Libraries from Known Manufacturers -budniok 40+ Free CAD Block Libraries from Known Manufacturers -eaton 40+ Free CAD Block Libraries from Known Manufacturers -schnieder
40+ Free CAD Block Libraries from Known Manufacturers -schrack 40+ Free CAD Block Libraries from Known Manufacturers -noark
HVAC Industry Parts Catalogs
40+ Free CAD Block Libraries from Known Manufacturers -wilo 40+ Free CAD Block Libraries from Known Manufacturers -viesman 40+ Free CAD Block Libraries from Known Manufacturers -reflex 40+ Free CAD Block Libraries from Known Manufacturers -valliant
40+ Free CAD Block Libraries from Known Manufacturers -ksb 40+ Free CAD Block Libraries from Known Manufacturers -grundfos 40+ Free CAD Block Libraries from Known Manufacturers -saunier duval 40+ Free CAD Block Libraries from Known Manufacturers -salmson
40+ Free CAD Block Libraries from Known Manufacturers -kamo 40+ Free CAD Block Libraries from Known Manufacturers -clage 40+ Free CAD Block Libraries from Known Manufacturers -delta 40+ Free CAD Block Libraries from Known Manufacturers -flowserve
40+ Free CAD Block Libraries from Known Manufacturers -acv 40+ Free CAD Block Libraries from Known Manufacturers -efar 40+ Free CAD Block Libraries from Known Manufacturers -wavin 40+ Free CAD Block Libraries from Known Manufacturers -magnaplast
40+ Free CAD Block Libraries from Known Manufacturers -heiztechnik 40+ Free CAD Block Libraries from Known Manufacturers -chemowent 40+ Free CAD Block Libraries from Known Manufacturers -bhres 40+ Free CAD Block Libraries from Known Manufacturers -wilso us
Design Quickly and Conveniently
CP-Manufacturers also gives you access to three important commands:
Attributes and Descriptions:
During the symbol and object insertion, the CP-Manufacturers add-on, adds various descriptions and technical parameters. This data is stored as attributes. The Attributes and Descriptions command allows you to edit the attributes, as well as to add descriptions (as a simple text) into the drawing. All data that is used in the attributes can be later used during the BOM creation.
Frames and Tables:
The Frames and Tables command offers you a convenient way to insert standard frames and tables to the drawing.
Bill of Materials:
The Bill of Materials command allows you to easily prepare specifications and BOMs (Bills of Materials). You can be print or export this to multiple formats, including pdf, rtf (doc), xls, xml, csv, html and more. It also makes it possible to automatically create graphical legends.
Where to download these free CAD libraries
Some of the CP-Manufacturers libraries can be downloaded for free from www.cadprofi.com. Alternatively, head over to the Bricsys App Store.
All manufacturers' libraries are included in CADprofi -- a professional CAD program that helps in designing architectural and mechanical projects, as well as plumbing and electrical installations based on both national and international standards.
Karol Klimowicz
door Karol Klimowicz - Digital Marketing specialist at CADprofi
Karol is a digital marketing specialist at CADprofi. During his free time he creates websites in which he teaches the English language to Polish and German speakers.
23 juli 2024 3 min
Polyline Editing in BricsCAD
15 juli 2024 3 min
Volg ons op sociale media
