Mechanical
Pushing the Limits of Parametric Modeling with BricsCAD® Mechanical
By Rose Barfield 4 分 2021年2月14日
If you were watching the Bricsys® Digital Summit in October 2020, you might have noticed that the Mechanical team presented the latest developments for BricsCAD® Mechanical V21 with the aid of a detailed assembly -- "The Brewery". The parametric model consisted of over 3,000 parts (of which 500 are unique) and included more than 1,000 constraints, the majority of which were added automatically by BricsCAD. Despite this level of complexity, the model still runs flawlessly.
Unfortunately, there simply wasn't enough time during the presentation to showcase the incredible complexity and level of detail added to the model by the team. Fortunately, the Bricsys Blog has the opportunity to take the model apart and have an in-depth look at the brewery in all its glory.
The Assembly
The Brewery showcased BricsCAD Mechanical at its finest, from a fully animated bottle filling assembly, to an elaborate, parametric system of pipes, all created using BricsCAD!
This year's design was inspired by the maltese cross mechanism (geneva drive), which converts continuous rotary movement into intermittent rotation. The mechanism was used in The Brewery to push the bottles onto the belt at uniform intervals.
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- geneva drive
Geneva drive or maltese cross mechanism in action.
The assembly truly demonstrated how BricsCAD Mechanical provides, not only 2D modeling but also 3D modeling capabilities, and fully showcased BricsCAD Mechanical's parametric and constraint capabilities. The assembly was used by the quality assurance team to ensure that BricsCAD Mechanical V21 was ready for you, our BricsCAD users.
Parametrics and constraints
The Brewery really makes the most of BricsCAD Mechanical's parametric modeling capabilities and demonstrates just how easy it is to create a model with parametrically variable, equipment configurations.
In the Brewery, you accommodate different bottle sizes in the assembly and parametrically change the distance between the nozzles, the forks on the bottle spacer assembly, the rails on the conveyer belt, the rotary platform, and even the frame assembly.
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- diameter
You can also change the number of nozzles and the number of forks on the bottle spacer assembly, again by altering just one parameter.
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- nosel fork
Another cool feature in The Brewery that it demonstrates how it is possible, in BricsCAD, to create limits for parameter values. There are 2 parameters that limit the movement of the nozzle valve before it opens and ensure that the bottle spacer stops at the right point.
There are also parameters in the model that can be used to animate the chain, rotate the rotary platform and drive other moving parts!
Arrays
The arrays used in the cap duct and cap rotation drum assemblies were created along a path, whilst the chain array was created on a closed polyline. To move the arrayed elements along the path, you need only to change the offset parameter.
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- array
Creation of models from structural elements
Meanwhile, the frame demonstrates the possibility for users to create models from structural elements.
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- frame
Parametric parts
Standard parts are used to connect the various parts of the brewery together. There are over 100 parametric parts available for use in BricsCAD Mechanical. Because The Brewery was created using standard parametric parts, the whole of the piping system can be edited dynamically with the manipulator.
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- pipes
Sheet metal
And of course, I don't need to remind you that the control box was created live during the presentation by converting a solid into sheet metal in less than 3½ minutes, which included automatic junction creation!
Pushing the Limits of Parametric Modeling with BricsCAD<sup>®</sup> Mechanical- sheet metal
Build your own Parametric models with BricsCAD Mechanical
Try BricsCAD Free
Rose Barfield
LinkedIn logo (b&w)
Roseは、ユーザーからのフィードバックを受け、BricsCAD製品を改善する役割を担っています。BricsCAD に来る前は、彼女自身もCADユーザーで、自動車、航空宇宙、防衛産業でテクニカルイラストレーターとして働いていました。モノの仕組みを知り、分解して、(できれば)また組み立てるのが大好き。
2024年4月15日 1 分
BricsCAD® Pro V24.2 - パフォーマンスの改善
BricsCAD V24.2が登場し、効率と安定性の向上を約束する一連のパフォーマンス改善がもたらされました。 あらゆる業界の製図者、設計者、ファブリケーター向けに調整された最新バージョンは、構築、製造、製造プロセスに不可欠な詳細な設計ドキュメントの作成を加速することに重点を置いています。 では、V24.2 で成果物化までの時間を短縮する機能強化について詳しく見ていきましょう。
2024年4月8日 4 分
BricsCAD® v24.2での図面の互換性の強化
V24.2では、BricsCAD®のDWG互換性をさらに強化し、2D図面作成ワークフローに焦点を当てることで、設計ドキュメントを迅速に作成できるようにしました。 最もスムーズなコラボレーションを作成するために、BricsCADで作成した図面を他のDWGベースのCADプログラムで開いて編集できるようにしました。 それでは、私たちが行った機能強化について見ていきましょう!
2024年3月25日 4 分
BricsCAD® LiteおよびPro V24.2の新機能
最新のアップデートでは、BricsCAD® V24.2は、2D図面の作成を向上させるための多くの新機能と拡張機能をもたらします。 より直感的なユーザーエクスペリエンスを導入し、パフォーマンスと安定性を向上させ、生産性をさらに向上させる新機能と拡張機能を追加しました。 このリリースでは、2D製図および設計プロジェクトが円滑に進行するために必要な精度と多機能性を実現するワークフローが提供されます。
ソーシャルメディアでフォローする
