Gestion de documents
View 2D & 3D CAD files online with Bricsys 24/7
Par Rose Barfield 3 min 15 août 2019
Bricsys 24/7 allows you to view 3D files online, in your browser. Thanks to Bricsys 24/7's built-in 3D viewer, every person working on a project can open, explore, and annotate 3D models whenever they need to, even without CAD software installed on their machine. This includes all BricsCAD native .dwg files.
If you are looking for a way to view .dwg files for free check out BricsCAD ShapeODA's online .dwg converter
CAD file types supported by Brisys 24/7's online viewer:
  • dwg
  • dwf
  • dwfx
  • dxf
  • dgn
  • plt
  • hp
  • hpg
Bricsys 24/7 also provides full IFC (Industry Foundation Classes) support. Learn more about IFC.
Online viewer
You can upload, download, share, and view 3D models from your browser, without installing any software. There is also a direct connection from BricsCAD and BricsCAD BIM to Bricsys 24/7 so now it's even easier to share your files!
View 2D & 3D CAD files online with Bricsys 247- 3D viewer
No experience? No problem!
Bricsys 24/7 online 3D viewer is super easy to use, even with no experience working with CAD programs. Rotate and zoom in and out of the model, all from your browser. Use Bricsys 24/7's native tools to create a slice through the building. You can even add annotations to the models and you have full control over who can see the comments: keep them private, just share with the architect or make them viewable to everyone.
View 2D & 3D CAD files online with Bricsys 247- slice anotate
View BIM files in-browser
If you have projects with vast amounts of BIM data and plenty of associated documents, that's no problem. 24/7's model server manages all of the information required in a construction project.
It's easy to browse through a model's structure. Use the panel on the left-hand side of the screen to isolate an element and access any additional data related to that entity. You can query, merge, and filter the view depending on your individual needs.
View 2D & 3D CAD files online with Bricsys 247- structure
Full external reference file management
In addition, Bricsys 24/7 supports models using external references (XRefs). Bricsys 24/7 will recognize and automatically manage links between files.
XRefs allow a single file to reference other files and are typically used in large projects to keep down file sizes and allow people to work on different parts of a model at the same time. Learn more about XRefs.
More file types
Bricsys 24/7 doesn't just support .dwg and CAD files! It also offers in-browser support for over 70 different file types. Find the complete list of file types supported by Bricsys 24/7.
Ready to share your files online?
Find out more about Bricsys 24/7 at www.bricsys.com. Easy to try, easy to buy, easy to own. That's Bricsys. Try all of our products, for free for 30 days. You'll love what we've built for you with the Bricsys product family.
15 avril 2024 3 min
BricsCAD® Pro V24.2 - Amélioration des performances
BricsCAD V24.2 est désormais disponible, avec de multiples améliorations des performances qui ne manqueront pas d'accroître votre efficacité et de renforcer la stabilité. Conçue pour les dessinateurs, les concepteurs et les fabricants de tous les secteurs, cette nouvelle version cherche à accélérer la création de la documentation, sans lésiner sur la précision, afin de répondre aux exigences essentielles des processus de construction et de fabrication. Examinons de plus près tous les avantages de la v24.2 pour accélérer votre délai de livraison.
8 avril 2024 4 min
Amélioration de la compatibilité des dessins dans BricsCAD® V24.2
Dans la v24.2, la compatibilité DWG de BricsCAD® gagne du terrain. Créer la documentation de conception devient plus rapide grâce aux flux de travail de Dessin 2D. Pour une collaboration toujours plus fluide, vous pouvez ouvrir et modifier les dessins BricsCAD dans tout autre programme de CAO basé sur le format DWG. Découvrons sans tarder les nouvelles améliorations !
25 mars 2024 4 min
Nouveautés de BricsCAD® Lite and Pro V24.2
Dans sa dernière mise à jour, BricsCAD® V24.2 introduit de nombreuses fonctionnalités innovantes et améliorées pour passer au niveau supérieur en matière de Dessin 2D. Nous avons renforcé l'intuitivité de l'expérience utilisateur, amélioré les performances et la stabilité et ajouté de nouvelles fonctionnalités avancées pour continuer à accroître votre productivité. Cette version livre des flux de travail qui vous offre le niveau de précision et de polyvalence dont vous avez besoin pour exécuter vos projets de dessin et de conception 2D avec efficacité.
Suivez-nous sur les réseaux sociaux
