Applications
From Raster - to CAD - to Digital
Par Gordon Lewis 2 min 25 mars 2020
Engineering Designers have taken advantage of the GTX industry-leading technical imaging software that has been providing cost-effective solutions for over three decades!
GTX Bridging Between Your Paper & CAD/EDM/GIS Environments!
  • 100% compatible -- built with BricsCAD® V20 API
  • Works on both BricsCAD® Pro & Platinum V20
  • Raster-To-Vector Conversion (CAD/Contour)
  • Raster-To-Text Recognition
  • Vector-To-Raster Conversion
  • Automatic Image Clean Up
  • Raster Object Editing
  • Raster/Vector Snapping
  • Intelligent Object Picking/ Selection
  • PDF Import/Export
  • PDF Conversion to TIFF
If you are working with scanned paper drawings that have been saved as a .PDF or .Tif file format, then GTXRaster CAD® 2020 Series provides you with the most cost effective raster cleanup, raster editing or raster-to-vector conversion solution. When all you need to do is make a quick and simple change, whether its changing text or geometry in the drawing, GTXRaster CAD® 2020 Series will save you time and money, without the need to start from scratch.
From Raster - to CAD - to Digital- BricsCAD-and-GTX17196-1024x713
GTX solutions are designed and developed for use in the following industries:
  • Mechanical CAD (MCAD)
  • Automated Mapping and Facilities Management (AM/FM)
  • Architectural, Engineering and Construction (AEC)
  • Geographical Information Systems (GIS)
  • Power Generation, Oil and Gas
  • Military
  • Government
GTXRaster CAD® 2020 Series for BricsCAD V20 has been fully ported to the 64-bit platform and can run as a native 64-bit application directly on the Windows 10 x64 Edition, Windows 8/8.1 x64 Edition and Windows 7 x64 Edition.
With the latest licensing technology, users will benefit with the FLEXENABLED® Software licensing program -- using the FlexeraTM FLEXnet Publisher -- for either standalone single-user installation, or for multiple users with network installation.
Discover more 3rd party BricsCAD apps
GTXRaster CAD® 2020 Series and hundreds of other applications are available on the BricsCAD App Store.
Download BricsCAD free for 30-days
Start Using BricsCAD Today
Permanent or subscription licenses that work in all languages, in all regions.
Gordon Lewis
par Gordon Lewis - General Manager at GTX Europe Ltd.
Gordon Lewis, General Manager for GTX Europe Ltd, has been at GTX for over 19 years, currently living in Portsmouth, Great Britain, enjoys Football, Running and vintage Lambretta’s.
15 avril 2024 3 min
BricsCAD® Pro V24.2 - Amélioration des performances
BricsCAD V24.2 est désormais disponible, avec de multiples améliorations des performances qui ne manqueront pas d'accroître votre efficacité et de renforcer la stabilité. Conçue pour les dessinateurs, les concepteurs et les fabricants de tous les secteurs, cette nouvelle version cherche à accélérer la création de la documentation, sans lésiner sur la précision, afin de répondre aux exigences essentielles des processus de construction et de fabrication. Examinons de plus près tous les avantages de la v24.2 pour accélérer votre délai de livraison.
8 avril 2024 4 min
Amélioration de la compatibilité des dessins dans BricsCAD® V24.2
Dans la v24.2, la compatibilité DWG de BricsCAD® gagne du terrain. Créer la documentation de conception devient plus rapide grâce aux flux de travail de Dessin 2D. Pour une collaboration toujours plus fluide, vous pouvez ouvrir et modifier les dessins BricsCAD dans tout autre programme de CAO basé sur le format DWG. Découvrons sans tarder les nouvelles améliorations !
25 mars 2024 4 min
Nouveautés de BricsCAD® Lite and Pro V24.2
Dans sa dernière mise à jour, BricsCAD® V24.2 introduit de nombreuses fonctionnalités innovantes et améliorées pour passer au niveau supérieur en matière de Dessin 2D. Nous avons renforcé l'intuitivité de l'expérience utilisateur, amélioré les performances et la stabilité et ajouté de nouvelles fonctionnalités avancées pour continuer à accroître votre productivité. Cette version livre des flux de travail qui vous offre le niveau de précision et de polyvalence dont vous avez besoin pour exécuter vos projets de dessin et de conception 2D avec efficacité.
Suivez-nous sur les réseaux sociaux
