Applications
40+ Free CAD Block Libraries from Known Manufacturers - CADprofi
Par Karol Klimowicz 4 min 12 août 2020
CP-Manufacturers - CAD block libraries from CADprofi - gives you access to more than 40 free CAD libraries from world-known manufacturers. Use them for sanitary, central heating, ventilation, electrical and other types of installations. Some of these libraries are available free, as a stand-alone application and others are included as part of the BricsCAD-CADprofi application.
These libraries are perfect for:
  • Apparatus and electrical switchboards
  • Busbars, mesh cable trays
  • Lighting protection system
  • Armature, pumps, boilers, tanks, etc
  • Elements of exhaust fumes/chimney installations
  • Elements of plumbing installations
  • Typical boiler systems
Electrical Industry Parts Catalogs
40+ Free CAD Block Libraries from Known Manufacturers -abb 40+ Free CAD Block Libraries from Known Manufacturers -hager 40+ Free CAD Block Libraries from Known Manufacturers -legrand 40+ Free CAD Block Libraries from Known Manufacturers -eti
40+ Free CAD Block Libraries from Known Manufacturers -lovato 40+ Free CAD Block Libraries from Known Manufacturers -dehn 40+ Free CAD Block Libraries from Known Manufacturers -trilux 40+ Free CAD Block Libraries from Known Manufacturers -trilux
40+ Free CAD Block Libraries from Known Manufacturers -bkj 40+ Free CAD Block Libraries from Known Manufacturers -elko bis 40+ Free CAD Block Libraries from Known Manufacturers -pulsar 40+ Free CAD Block Libraries from Known Manufacturers -pawbol
40+ Free CAD Block Libraries from Known Manufacturers -tkrem 40+ Free CAD Block Libraries from Known Manufacturers -puk 40+ Free CAD Block Libraries from Known Manufacturers -lamel 40+ Free CAD Block Libraries from Known Manufacturers -bcs
40+ Free CAD Block Libraries from Known Manufacturers -fandf 40+ Free CAD Block Libraries from Known Manufacturers -budniok 40+ Free CAD Block Libraries from Known Manufacturers -eaton 40+ Free CAD Block Libraries from Known Manufacturers -schnieder
40+ Free CAD Block Libraries from Known Manufacturers -schrack 40+ Free CAD Block Libraries from Known Manufacturers -noark
HVAC Industry Parts Catalogs
40+ Free CAD Block Libraries from Known Manufacturers -wilo 40+ Free CAD Block Libraries from Known Manufacturers -viesman 40+ Free CAD Block Libraries from Known Manufacturers -reflex 40+ Free CAD Block Libraries from Known Manufacturers -valliant
40+ Free CAD Block Libraries from Known Manufacturers -ksb 40+ Free CAD Block Libraries from Known Manufacturers -grundfos 40+ Free CAD Block Libraries from Known Manufacturers -saunier duval 40+ Free CAD Block Libraries from Known Manufacturers -salmson
40+ Free CAD Block Libraries from Known Manufacturers -kamo 40+ Free CAD Block Libraries from Known Manufacturers -clage 40+ Free CAD Block Libraries from Known Manufacturers -delta 40+ Free CAD Block Libraries from Known Manufacturers -flowserve
40+ Free CAD Block Libraries from Known Manufacturers -acv 40+ Free CAD Block Libraries from Known Manufacturers -efar 40+ Free CAD Block Libraries from Known Manufacturers -wavin 40+ Free CAD Block Libraries from Known Manufacturers -magnaplast
40+ Free CAD Block Libraries from Known Manufacturers -heiztechnik 40+ Free CAD Block Libraries from Known Manufacturers -chemowent 40+ Free CAD Block Libraries from Known Manufacturers -bhres 40+ Free CAD Block Libraries from Known Manufacturers -wilso us
Design Quickly and Conveniently
CP-Manufacturers also gives you access to three important commands:
Attributes and Descriptions:
During the symbol and object insertion, the CP-Manufacturers add-on, adds various descriptions and technical parameters. This data is stored as attributes. The Attributes and Descriptions command allows you to edit the attributes, as well as to add descriptions (as a simple text) into the drawing. All data that is used in the attributes can be later used during the BOM creation.
Frames and Tables:
The Frames and Tables command offers you a convenient way to insert standard frames and tables to the drawing.
Bill of Materials:
The Bill of Materials command allows you to easily prepare specifications and BOMs (Bills of Materials). You can be print or export this to multiple formats, including pdf, rtf (doc), xls, xml, csv, html and more. It also makes it possible to automatically create graphical legends.
Where to download these free CAD libraries
Some of the CP-Manufacturers libraries can be downloaded for free from www.cadprofi.com. Alternatively, head over to the Bricsys App Store.
All manufacturers' libraries are included in CADprofi -- a professional CAD program that helps in designing architectural and mechanical projects, as well as plumbing and electrical installations based on both national and international standards.
Karol Klimowicz
par Karol Klimowicz - Digital Marketing specialist at CADprofi
Karol is a digital marketing specialist at CADprofi. During his free time he creates websites in which he teaches the English language to Polish and German speakers.
15 avril 2024 3 min
BricsCAD® Pro V24.2 - Amélioration des performances
BricsCAD V24.2 est désormais disponible, avec de multiples améliorations des performances qui ne manqueront pas d'accroître votre efficacité et de renforcer la stabilité. Conçue pour les dessinateurs, les concepteurs et les fabricants de tous les secteurs, cette nouvelle version cherche à accélérer la création de la documentation, sans lésiner sur la précision, afin de répondre aux exigences essentielles des processus de construction et de fabrication. Examinons de plus près tous les avantages de la v24.2 pour accélérer votre délai de livraison.
8 avril 2024 4 min
Amélioration de la compatibilité des dessins dans BricsCAD® V24.2
Dans la v24.2, la compatibilité DWG de BricsCAD® gagne du terrain. Créer la documentation de conception devient plus rapide grâce aux flux de travail de Dessin 2D. Pour une collaboration toujours plus fluide, vous pouvez ouvrir et modifier les dessins BricsCAD dans tout autre programme de CAO basé sur le format DWG. Découvrons sans tarder les nouvelles améliorations !
25 mars 2024 4 min
Nouveautés de BricsCAD® Lite and Pro V24.2
Dans sa dernière mise à jour, BricsCAD® V24.2 introduit de nombreuses fonctionnalités innovantes et améliorées pour passer au niveau supérieur en matière de Dessin 2D. Nous avons renforcé l'intuitivité de l'expérience utilisateur, amélioré les performances et la stabilité et ajouté de nouvelles fonctionnalités avancées pour continuer à accroître votre productivité. Cette version livre des flux de travail qui vous offre le niveau de précision et de polyvalence dont vous avez besoin pour exécuter vos projets de dessin et de conception 2D avec efficacité.
Suivez-nous sur les réseaux sociaux
