3D modeling icon3D Modeling
Discover 3D Modeling with BricsCAD
Discover the BricsCAD Pro difference. Professional yet familiar with 2D CAD with flexible 3D CAD modeling in the same native DWG environment. Open 2D drawings, 3D models, or point clouds and work freely in 2D, 3D, or both. Further boost productivity with AI-driven drafting and modeling tools, plus drawing optimization tools to super-charge drawing performance.
BricsCAD® BIM V24: Quickest path to 3D from 2D
With BricsCAD® BIM V24's new modeling tools, you can transition from a 2D plan to a 3D model and convert your design concepts into 3D representations quickly and easily! Ppull 2D plans into 3D to create solid objects, better identify structures and entities with Top View mode, and convert everything into a complete BIM project.
Modelado 3D
Dibujo 2D
BIM
BricsCAD® V24: una experiencia de usuario moderna
Si es un usuario de CAD que se movió a BricsCAD, acostumbrarse a diferencias menores puede ralentizarle. Para ayudarle a realizar el cambio, hemos agregado orientación al producto directamente en BricsCAD. Con nuestra nueva y mejorada página de inicio, le resultará fácil seleccionar plantillas, una lista de dibujos abiertos recientemente y la opción de fijar archivos usados recientemente en la parte superior de su lista.
Dibujo 2D
Modelado 3D
Mechanical
BIM
BricsCAD® V24: What's New in BricsCAD® BIM?
With BricsCAD® BIM V24, we wanted to give you the tools you need. Many of our users receive 2D drawings from designers for at least 40% - 50% of their projects, so they need to convert their 2D drawings into 3D and BIM models for visualization, coordination, planning, and quantity takeoff. This conversion is made simpler with BricsCAD BIM V24's tools, which are easy to use, familiar, and intelligent when needed.
Dibujo 2D
Modelado 3D
BIM
¿Qué hay de nuevo en BricsCAD® V24?
¡Bienvenido a BricsCAD® V24! El CAD profesional sin compromiso. Esta versión incluye nuevas funciones y actualizaciones, lo que facilita el aprendizaje, el uso y la adopción de BricsCAD. ¡Echemos un vistazo a las novedades de BricsCAD V24!
Dibujo 2D
Modelado 3D
BIM
Mechanical
Which BricsCAD® is right for you?
If you're considering BricsCAD®, you're probably wondering – which BricsCAD is right for me? There are five BricsCAD editions so you can choose the BricsCAD that suits your needs best. Whether you're working in 2D, 3D or both, there's a BricsCAD for you. Choose from BricsCAD® Lite, BricsCAD® Pro, BricsCAD® BIM, BricsCAD® Mechanical or BricsCAD® Ultimate. Let's take a look at the various BricsCAD product levels!
Dibujo 2D
Modelado 3D
BIM
Mechanical
Convertir archivos PDF a DWG con BricsCAD®
Puede convertir archivos PDF a archivos DWG rápida y fácilmente en BricsCAD®. Cuando convierte un PDF a un archivo DWG, BricsCAD® convierte líneas rectas en polilíneas, fuentes en MTEXT y sólidos rellenos en sombreados, ¡proporcionándole un archivo de dibujo en lugar de su PDF! ¡Así es como puede hacerlo!
Dibujo 2D
Modelado 3D
BIM
Fabricación y Mechanical
BricsCAD® en 3D: Estilos visuales
Cuando trabaja con modelos 3D en BricsCAD®, puede usar estilos visuales para controlar la visualización de sólidos y superficies 3D para dar esos toques finales a sus diseños. Echemos un vistazo a cómo puede usar estilos visuales en BricsCAD.
Modelado 3D
BIM
Mechanical
Primeros pasos con BricsCAD®: opciones de prueba y licencia
¿Estás considerando BricsCAD? Entonces probablemente te estés preguntando qué opciones de licencia están disponibles cuando eliges BricsCAD. Puede aprovechar la prueba gratuita de 30 días para probar BricsCAD y sus distintas versiones y decidir qué edición se adapta mejor a sus necesidades. Cuando compra BricsCAD, puede elegir entre nuestras opciones de licencia flexibles. ¡Echemos un vistazo a las diferentes opciones de licencia!
Dibujo 2D
Modelado 3D
BIM
Mechanical
BricsCAD® BIM V23.2 Características nuevas y mejoradas
BricsCAD® BIM V23.2 tiene algunas mejoras interesantes para enriquecer el flujo de trabajo BIM para diseñadores e ingenieros, lo que hace que sea más fácil y eficiente crear modelos BIM precisos y detallados.
BIM
Dibujo 2D
Modelado 3D
Inteligencia artificial en BricsCAD® BIM hoy: ¿con qué finalidad?
¿Sabía que la automatización y la inteligencia artificial en BricsCAD® BIM realmente pueden ayudarlo en sus flujos de trabajo BIM? Para mostrarle cómo, hemos esbozado seis procesos clave en la fase de diseño de un proyecto típico de construcción o reforma.
BIM
Dibujo 2D
Modelado 3D
Desarrollando IA Generativa en BricsCAD® - ¿Cuál es el punto?
La IA Generativa es una palabra de moda, pero eso no significa que sea una moda pasajera. Los sectores de la arquitectura y la ingeniería adoptarán esta tecnología más rápidamente a medida que se disponga de un mayor número de soluciones para resolver problemas muy bien delimitados, como la clasificación de objetos 3D en elementos de construcción y clases de sistemas de ingeniería. Entonces, ¿cómo estamos desarrollando IA Generativa en BricsCAD®?
Dibujo 2D
Modelado 3D
BIM
Mechanical
What to do when you find an issue in BricsCAD®
Although BricsCAD® is highly stable and lightning-fast, occasionally, as with any piece of software, you might run into an issue. In the event you do find something not working properly, follow these guidelines to make sure your problem gets addressed quickly.
Dibujo 2D
Modelado 3D
Mechanical
BIM
