2D Zeichnen
BricsCAD: Discover the Difference: Improve Performance with Simplify
Von Gavin England 2 min 23. August 2022
In ‘BricsCAD: Discover the Difference’, we’re looking at how you can improve your productivity with innovative tools inside BricsCAD. Today, we show you some quick ways to automatically simplify polylines with geometric accuracy in your CAD drawings. Let’s look at the function ‘Simplify’ in BricsCAD.
How to Simplify complex CAD geometry
The Simplify function reduces the amount of data required when working on digitized plans in CAD, which often show aspects such as rivers or coastlines in more detail than required. Add to this the rapid increase in data obtained from scanning devices, and the design can very quickly contain geometry with too much detail to work efficiently.
Optimize drawings - automatically simplify polylines
Simplify in BricsCAD is a drawing optimisation tool which automatically simplifies a polyline by reducing the number of vertices. This lets you work easily on any heavy and complex polylines imported from digitized maps or scanning devices. You can control the level of detail you need, and the drawing remains manageable with optimal performance.
Get the right balance of geometrical accuracy and visual detail
Simplify removing vertex in polylines
In fact, detailed lines can sometimes look innocuous yet may be reducing the performance of the overall drawing with vertices overly detailed. With Simplify, you just select a polyline and remove these unwanted vertices. The angle and distance parameters specify the conditions for vertex removal, so you get the right balance of geometrical accuracy and visual detail.
Once simplified, the vertices are reduced and the line is far more manageable to select and work with. The polyline could be simplified again, further reducing detailed vertices as your CAD workflow demands.
Simplify is just one of many unique, advanced and intelligent tools innovated in the BricsCAD suite.
Simplify is just one of many unique, advanced and intelligent tools innovated in the BricsCAD suite. Follow our blog series on why BricsCAD is delivering a difference. And discover more optimization tools with a BricsCAD free trial download today.
15. April 2024 3 min
BricsCAD® Pro V24.2 - Leistungsverbesserungen
BricsCAD V24.2 ist da und bringt eine Reihe von Leistungsverbesserungen mit, die eine Steigerung der Effizienz und Stabilität versprechen. Die neueste Version ist auf technische Zeichner, Designer und Hersteller aller Branchen zugeschnitten und konzentriert sich auf die Beschleunigung der Erstellung detaillierter Designdokumentation, die für Bau-, Fertigungs- und Herstellungsprozesse unverzichtbar ist. Sehen wir uns die Verbesserungen in V24.2 genauer an, die Ihre Lieferzeit verkürzen werden.
8. April 2024 4 min
Verbesserte Zeichnungskompatibilität in BricsCAD® V24.2
In V24.2 haben wir die DWG-Kompatibilität von BricsCAD weiter verbessert, um die schnelle Erstellung von Designdokumentation zu gewährleisten, indem wir uns auf den Arbeitsablauf zur Erstellung von 2D-Zeichnungen konzentrieren. Um eine reibungslose Zusammenarbeit zu gewährleisten, haben wir sichergestellt, dass Sie die in BricsCAD erstellten Zeichnungen in anderen DWG-basierten CAD-Programmen öffnen und bearbeiten können. Schauen wir uns die Verbesserungen an, die wir vorgenommen haben!
25. März 2024 4 min
Folgen Sie uns in den sozialen Netzwerken
