You can create simple components like flange couplings quickly and easily in BricsCAD. Simply start with a 2D drawing and use BricsCAD's intuitive 3D tools to create your 3D model. Let's take a step-by-step look at how you can create a flange coupling.
Create a circular profile
  • First, you'll need to create a circular profile
circular profile 1 1
  • Draw a line starting from the center at a 45 degree angle from the horizontal
    line angle 1
  • Create circles with the desired dimensions
circular profile 2
  • Erase the line and the outer circle
Create arcs
  • Fillet the circles to create arcs
    arcs
  • Choose polar array to copy the entities along the circumference of the circle, aligned with the radius.
    polar array
Arrays
  • Explode the array entity and use TRIM to remove unwanted portions of the entities
    TRIM
  • Join the outer profile to a single entity and take a top, front, left isometric view
    top front left
Extrude
  • Use the EXTRUDE command to extrude the outer profile and the inner circles to a distance of 3 units and perform a subtraction
    extrude
  • Copy the inner circle as you will need to use the circle twice while extruding
    copy inner circle
  • Extrude the outer and inner circles to a distance of 8.5 units, and subtract the outer solid from the inner solid
    subtraction
  • Extrude the remaining circles to a distance of 12 units and subtract the inner solid from the outer solid
Create a hole
  • Take a bottom view of the component and use the Push/Pull tool
    push pull
  • Pull the circular face upward from the bottom to create a hole
    create hole
Final touches
  • Use the UNION command to union all solids to get a single solid
    union
  • Create a fillet at the edge with a radius of 1.5 units
    fillet 2
And that's it! Follow these instructions and you'll be able to create a flange coupling in minutes.
Watch the tutorial
If you prefer a video tutorial, check out this video on the Bricsys YouTube channel, and subscribe to our channel to keep up with our BricsCAD tutorials.
Try BricsCAD!
See how you can create 3D models quickly and easily for yourself, try BricsCAD for free for 30 days!
Bricsys Icon
The Octave BricsCAD Team
The Octave BricsCAD Team is committed to delivering you practical tips, tricks, how-to's, and industry insights - so you can make the most out of BricsCAD.
