Search
2D Drafting
5 Ways to Edit a Polyline in BricsCAD - Tuesday Tips
By Rose Barfield 4 min 20 กันยายน 2564
When you start a new CAD drawing, the first thing you'll probably want to do is draw a line and the second you've done it, you'll probably want to edit that line! The good news is that whether you're adding a new vertex or editing the bulge value, BricsCAD® gives you plenty of ways to edit a line or a polyline.
1) The Quad
Use the Quad to add a vertex to a polyline, adjust the bulge of a segment, delete a segment or stretch a segment.
null
How to edit a polyline in BricsCAD using the Quad:
  1. Turn the Quad On.
  2. Move the cursor over the polyline.
  3. Hold Ctrl.
  4. Move the cursor to the Quad and select a command.
  5. Edit the polyline.
2) PEDIT
Use PEDIT to edit vertices, convert segments between arc and straight, break a polyline, reverse the direction, insert and delete a vertex, change the width of a segment and convert splines into polylines.
null
How to edit a polyline with the PEDIT command in BricsCAD:
  1. Enter PEDIT.
  2. Select the polyline.
  3. Choose from the options.
  4. Follow the instructions in the Command line.
3) The Properties Panel
Use the Properties Panel to edit your polyline and get extra information, such as the number of vertices and the elevation. You can change the width and bulge of polyline segments to make the polyline closed, open, and more.
null
To edit a polyline with the Properties Panel:
  1. Select the polyline.
  2. Open the Properties Panel.
  3. Use the options to edit the polyline.
4) Simplify
Sometimes polylines become more complex and memory-intensive than you would like. Use the SIMPLIFY command to reduce the complexity of a polyline.
null
How to reduce the complexity of a polyline in BricsCAD with SIMPLIFY:
  1. Enter SIMPLIFY.
  3. Choose your tolerance options in the Command line.
5) With commands
Use commands such as TRIMEXTEND and JOIN (which do exactly what they say on the tin) to edit polyline lines.
null
How to trim a polyline in BricsCAD:
  1. Enter TRIM.
  2. (Optional) Select cutting entity/entities.
  3. Click the line to be trimmed. The section will be deleted to the nearest cutting entity.
  4. (Optional) Hold Shift to extend instead of trim.
null
How to extend a polyline in BricsCAD:
  1. Enter EXTEND.
  2. (Optional) Select boundary entity/entities.
  3. Click the line to be extended. The section will be extended to the nearest cutting entity.
  4. (Optional) Hold Shift to trim the line instead of extend.
null
How to join polylines in BricsCAD:
  1. Enter JOIN.
  2. Select the entities to be joined.
  3. Press Enter.
    Note: polylines must be touching.
How else do you edit polylines in BricsCAD?
JOIN.
Know any ways that I have missed off the list? Let me know in the comments below.
Happy CADing!
Explore BricsCAD
Rose Barfield
LinkedIn logo (b&w)
17 กันยายน 2567 3 min
10 กันยายน 2567 3 min
BricsCAD Partner Apps for Civil and Survey Workflows
At Bricsys, we provide a solid foundation for our specialist survey and civil app developers to create specialist civil and survey tools that deliver robust and efficient workflows for BricsCAD users. Let’s see what updates and improvements our various developer partners have made to complement BricsCAD V24's civil and survey workflows.
These civil and survey applications are among multiple third-party applications supported by BricsCAD, with our developers working to improve their functionality and remain on pace with our new features introduced with every release.
9 กันยายน 2567 4 min
Embracing Digital Transformation in the Construction Industry with Bricsys 24/7®
The construction industry continually evolves, and digital transformation is reshaping how teams manage projects, communicate, and handle project documentation. When embracing digital solutions for construction projects, a common data environment (CDE) like Bricsys 24/7 is an excellent place to start. With a significant variance in the level of digital adoption across the industry, embracing and leveraging digital tools can help firms differentiate themselves by elevating operational efficiency and improving project outcomes.
Follow us on social media
