Desenare 2D
What is CAD/CAM? - Back to Basics?
De Rose Barfield 2 min 27 ianuarie 2021
What is CAD/CAM?
What is CAD/CAM? What does it stand for? What is computer-aided manufacturing and what has it got to do with CAD software? Keep reading to find out.
What does CAD/CAM stand for?
CAD/CAM is a combination of two acronyms:
CAD
Computer Aided Design   or   Computer Aided Drafting
CAM
Computer-Aided Manufacturing or   Computer-Aided Modeling   or   Computer-Aided Machining
The most common is Computer-Aided Manufacturing.
What is Computer-Aided Manufacturing?
Computer-Aided Manufacturing simply means any type of manufacturing that is created with the "aid" of a computer. This can be anything from the act of using a computer to control a machine that manufactures parts, to the use of a computer to assist in the management of a manufacturing plant.
CAM includes manufacturing techniques such as additive manufacturing (3D printing), laser cutting and computer numerical control (CNC) machining.
What is CADCAM- 3d printing
3D printing is a type of CAM
What is CAD/CAM?
CAD/CAM means literally: Computer-Aided Design & Computer-Aided Manufacturing. Both CAD and CAM are required to manufacture a part, it is unusual, although not impossible, to find one without the other. Generally, a part is first designed in a piece of CAD software and then sent to a CAM software package for manufacture.
What is CAM software?
CAM software is any software package that translates a CAD model into a language that the machine can understand. It tells the machine how to manufacture the part. Some software packages do both CAD and CAM.
More Back to Basics:
19 martie 2024 9 min
Ce este nou în BricsCAD® V24.2
BricsCAD® V24.2 este plin de caracteristici noi și îmbunătățite pentru desenul 2D, modelarea 3D, civil, topografie, BIM și fluxuri de lucru mecanice. Cu această versiune, echipa Bricsys a inclus mai multe caracteristici noi și îmbunătățiri pentru a vă ajuta să accelerați timpul de livrare și pentru a vă oferi o experiență CAD familiară. Așadar, haideți să ne aruncăm și să explorăm noutățile din BricsCAD V24.2!
10 martie 2024 6 min
Calea către automatizarea Scan to BIM cu BricsCAD® BIM V24
Noile instrumente de automatizare incluse în BricsCAD® BIM V24 fac procesul Scanare-către-BIM mai ușor și mai eficient! Dacă doriți o captură rapidă și precisă a realității obiectelor existente, aceste instrumente vor fi o completare excelentă a arsenalului dumneavoastră. Am adăugat instrumente precum Clasificator Nor Puncte, Detectare Camere Nor Puncte, Potrivire Camere Nor Puncte și Calcul Normal pentru norii de puncte structurați, pentru a vă ajuta să creați gemeni digitali pentru preluarea cantităților, să creați planuri de construcție precise și pentru gestionarea instalațiilor.
3 martie 2024 7 min
Desenați managementul sănătății cu BricsCAD® V24
Când lucrați la un model 3D, este esențial să vă asigurați că modelele dvs. sunt optimizate pentru performanță și eficiență mai bune! Acest lucru este ușor de realizat cu ajutorul instrumentelor de gestionare a stării de sănătate a desenelor din BricsCAD. Citiți mai departe pentru a afla cum puteți optimiza modelele 3D de mari dimensiuni și reduce dimensiunea fișierelor în BricsCAD V24.
Urmărește-ne pe rețelele sociale
