Aplicações
How to easily change CADprofi platform from AutoCAD® to BricsCAD®
Por Karol Klimowicz 3 min 7 de fevereiro de 2021
If you use CADprofi on AutoCAD® you can easily change your base CAD program to BricsCAD® and continue using CADprofi. In fact, this process is very simple, without any additional efforts or costs. That's because CADprofi detects all, installed CAD programs automatically!
What is CADprofi?
CADprofi is a popular CAD add-on that helps when designing architectural and mechanical projects, as well as plumbing and electrical installations.
How to easily change CADprofi platform from AutoCAD<sup>®</sup> to BricsCAD<sup>®</sup>- 1-e1611743233615
How to change your CADprofi Configuration to BricsCAD
Your CADprofi license is not restricted to a single CAD platform. If you choose to change your CAD platform, for example from AutoCAD to BricsCAD, you can still work on CADprofi easily!
The process is quite simple:
  1. After you have installed BricsCAD on your computer switch on the CADprofi Configuration program.
  2. Select BricsCAD as your chosen CAD platform and choose one of the 29 available languages:
    English, Bulgarian, Chinese Simplified, Croatian, Czech, Danish, Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Latvian, Lithuanian, Norwegian, Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovenian, Spanish, Swedish, Turkish or Ukrainian.
  3. Click the Configure CAD button and you are set!
How to Install CADprofi on a New Computer
CADprofi software possesses a very convenient editor for creating user symbols and objects. You have the option to add your own translations or to change the terminology. Additionally, you can define a list of "favorites". These features allow you to work in accordance with your own habits and preferences.
How to easily change CADprofi platform from AutoCAD<sup>®</sup> to BricsCAD<sup>®</sup>- user symbolsIf you decide to change, not only, your CAD platform but also to change your system (either by buying the new computer or by performing a factory reset) you should first backup your CADprofi data. Copy the UserData folder (located in the main CADprofi folder) and the Working_symbols and Working_folder and Working_parametrics (located in the Producers folder) to the new computer.
How to easily change CADprofi platform from AutoCAD<sup>®</sup> to BricsCAD<sup>®</sup>- translationsWhen you buy CADprofi you will receive a free year's subscription of additional benefits. This will allow you to download new updates free of charge and gives you the possibility to install CADprofi on two computers (e.g. your office computer and home notebook) allowing you greater flexibility. If you wish to change your system or move your license you should always remove the license from the current computer first.
To remove your CADprofi license from a computer:
  1. In the CADprofi -- About command, open the Activation and registration dialog window*.*
  2. Right-click on the serial number.
  3. Select the Remove option from the pop-up menu.
  4. You can now activate your serial number on a new computer or operating system.
To read more about CADprofi products or download the 30-day free demo please visit the CADprofi website.
15 de abril de 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 de abril de 2024 4 min
Compatibilidade de Desenho Aprimorada no BricsCAD® V24.2
Na V24.2, aprimoramos ainda mais a compatibilidade DWG do BricsCAD para garantir a rápida criação da documentação do projeto, concentrando-nos no fluxo de trabalho de criação de desenhos 2D. Para criar a colaboração mais suave, garantimos que você possa abrir e editar os desenhos criados no BricsCAD em outros programas CAD baseados em DWG. Vamos nos aprofundar nos aprimoramentos que fizemos!
25 de março de 2024 4 min
O que há de Novo no BricsCAD® Lite e Pro V24?
Na última atualização, o BricsCAD® V24.2 traz muitos recursos novos e aprimorados para elevar sua criação de desenhos 2D. Introduzimos uma experiência de usuário mais intuitiva, melhoramos o desempenho e a estabilidade e adicionamos recursos novos e aprimorados para aumentar ainda mais a sua produtividade. Esta versão oferece fluxos de trabalho para facilitar a precisão e a versatilidade que você necessita para que seus desenhos 2D e projetos de design sejam executados sem dificuldades.
Siga-nos nas mídias sociais
