In this series, you will learn how to work with CAD by following easy projects. Use only simple commands to build almost anything! For this tutorial, learn how to make a chess set.
How to Model a Chess Set in BricsCAD
Time to complete: 1-2 Hours
Difficulty: 6/10
Commands used:
Extrude
Manipulate
DmRevolve
DmPushPull
Offset
Mirror
Chamfer
Fillet
ArrayPolar
Explode
Subtract
Tutorial: Model a Chess Set in BricsCAD
Start by drawing the outline of half a Pawn.
Tip Use use polylines when possible.Then, Trim the excess linework and Join to create a closed polygon.
Use the Manipulator to copy the outline.
Use these copies as a guide and modify until you have something that looks like this:
Feel free to copy this image into BricsCAD and trace it.
Use DmRevolve to convert the outline into a solid.
Repeat for the other pieces. You should now have something that looks like this:
Create the slot on the Bishop:
- Extrude a rectangle. Use the Both sides option (Command line) and the Subtract mode.
To change the mode hit Ctrl. (See the Hotkey Assistant). - (Optional) Use DmPushPull to edit the slot.
To create the battlements on the Rook:
- Offset the edge of the top face.
- Extrude down.
- Extrude rectangles to create the crenels. Use the Both sides option (Command line) and the Subtract mode.
To create the Knight:
For the Queen:
For the King:
(Optional) To finish, add materials and render with the BricsCAD Enscape Integration.
Once you have completed this tutorial to model a chess set you should have something that looks like this.
Download BricsCAD free for 30-days
Get started with this model chess set tutorial in BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
