3D Modelleren
Dynamic User Coordinate Systems in BricsCAD® Shape - Joachim's Journey Part 15
Door Joachim Corijn 3 min 24 februari 2020
This time, we go down-under to the weird and wonderful land of Dynamic User Coordinate Systems (DUCS). This is a really powerful tool that allows you to draw on different planes in BricsCAD Shape. Not just on the "flat" x/y plane but the "vertical" z/y, z/x planes and pretty much any orientation in between.
What are the X Y and Z axes?
Imagine that X is "left and right" and Y "forward and backward" and Z is "up and down".
By default, BricsCAD® Shape draws along the X/Y plane and the 0 point on the Z-axis. Just think about it as though it's a large sheet of paper laid flat on the ground. This determines where you can start drawing a 2D or 3D object.
Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -flat logo-1024x576
Here you can see that the logo is resting flat on the x/y pane "the ground". This is the standard drawing plane for BricsCAD Shape.
How to draw on a different plane in BricsCAD Shape
If you want to draw at a different angle you need to change the UCS (User Coordinate System) -- "move the sheet of paper". The good news is that this is easy to do BricsCAD Shape.
You see this thing?:
Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -UCS
That's the UCSIcon. It basically tells you where the 0,0,0 coordinate is and which direction the x, y and z axes are.
To change the UCS (user coordinate system):
  1. If I have DUCS turned "on" (hit F6 to toggle it on and off)
  2. Execute a command.
  3. Hover over a face that represents the correct plane.
  4. Hit Shift to fix the UCS.
  5. Start drawing, the UCS will remain fixed for the duration of this command.Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -dynamic cube
Did you know?
It doesn't just work on flat surfaces, you can also use it on curves too!
Dynamic User Coordinate Systems in BricsCAD<sup>®</sup> Shape -dynamic spher
Curiosity not satisfied? Learn more about UCS.
What's next?
In this CAD lesson, we looked at ways to draw on different planes in BricsCAD Shape. In the next lesson, we'll take a look at ways to export your models.
Download BricsCAD Shape free
Watch the webinar "BricsCAD Shape in 10 minutes"
More CAD lessons:
  1. What is BricsCAD Shape?
  2. Download & Install
  3. Get started
  4. The Interface
  5. Commands
  6. Selecting Objects
  7. Transform
  8. Materials
  9. Components
  10. View Styles
  11. Layers
  12. Editing Entities
  13. More way to Edit Entities
  14. Arrays
  15. Dynamic User Coordinate Systems
  16. Export files and images
  17. Lazy Man's Guide to BricsCAD Shape
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
