Modélisation 3DMechanical Fabrication et Mécanique Construction
What’s New for Sheet Metal in BricsCAD® V22
Par Christian Lecomte 3 min 2 février 2022
New Sheet Metal features
In the sheet metal domain, the individual in charge of manufacturing preparation is rarely the project designer. Because of this, the probability that the project has to be reworked once, or multiple times, is very high. In addition, the CAD used for the design is often not the same as the CAD that is used for manufacturing preparation, even within the same company! Most industrial groups who use CAD today will be working in a multi-CAD environment. As a result, the ability to deeply rework is absolutely fundamental in sheet metal.
Most CAD systems often require you to restart from scratch due to difficulties that crop up in the reworking process. Thanks to the unique and simple reworking solutions, in BricsCAD you NEVER have to restart from scratch. This advantage is huge for productivity and project progress.
Converting a solid in BricsCAD® V22
BricsCAD can very easily convert and transform a solid into an unfoldable sheet metal object. This is even more true in BricsCAD® V22, where the function SMQuick automatically creates all the bends, junctions, cutouts, and reliefs with just one click, widening the gap between us and our competitors. Throughout this process, of course, the user remains free to manually change anything they deem necessary. You have full control over your project, whilst benefitting from these innovative features.
GIF 1 - Sheet Metal V22
It is important to note that BricsCAD can create junctions not only in straight edges but also on curved edges. This allows complex shapes to be converted to sheet metal with lofted bends intersections. This is unique to BricsCAD.
Dedicated functions increase ease of use in V22
BricsCAD® V22 also brings very interesting new capabilities. Now, it is much simpler to create jogs with the dedicated new function. This function is very convenient, but also intelligent. It automatically creates the necessary gap between adjacent coplanar flanges to avoid a collision. This feature works well for flat flanges or cylindrical flanges.
Another very nice new capability is creating flanges on curved edges, and the associated unfolding. This increases significantly the possibilities of design.
GIF 2 - Sheet Metal V22
We hope that this has given you an exciting insight into the developments and improvements for sheet metal in V22! Are you interested in learning more about sheet metal in BricsCAD? Please check out our full in-depth video.
But that’s not all that’s new for BricsCAD® V22!
These productivity-enhancing features, new in BricsCAD® V22, sit alongside many improvements to our core and stability. To see everything that's new for BricsCAD® V22, be sure to check the release notes and come back to the blog, as we will be exploring more features soon!
par Christian Lecomte
Christian Lecomte has been working with BricsCAD from its earliest days, specializing in its sheet metal utility. He is also the CEO of Brisys Official Partner, catalCAD.
15 avril 2024 3 min
BricsCAD® Pro V24.2 - Amélioration des performances
BricsCAD V24.2 est désormais disponible, avec de multiples améliorations des performances qui ne manqueront pas d'accroître votre efficacité et de renforcer la stabilité. Conçue pour les dessinateurs, les concepteurs et les fabricants de tous les secteurs, cette nouvelle version cherche à accélérer la création de la documentation, sans lésiner sur la précision, afin de répondre aux exigences essentielles des processus de construction et de fabrication. Examinons de plus près tous les avantages de la v24.2 pour accélérer votre délai de livraison.
8 avril 2024 4 min
Amélioration de la compatibilité des dessins dans BricsCAD® V24.2
Dans la v24.2, la compatibilité DWG de BricsCAD® gagne du terrain. Créer la documentation de conception devient plus rapide grâce aux flux de travail de Dessin 2D. Pour une collaboration toujours plus fluide, vous pouvez ouvrir et modifier les dessins BricsCAD dans tout autre programme de CAO basé sur le format DWG. Découvrons sans tarder les nouvelles améliorations !
Suivez-nous sur les réseaux sociaux
