Engineering Designers have taken advantage of the GTX industry-leading technical imaging software that has been providing cost-effective solutions for over three decades!
GTX Bridging Between Your Paper & CAD/EDM/GIS Environments!
- 100% compatible -- built with BricsCAD® V20 API
- Works on both BricsCAD® Pro & Platinum V20
- Raster-To-Vector Conversion (CAD/Contour)
- Raster-To-Text Recognition
- Vector-To-Raster Conversion
- Automatic Image Clean Up
- Raster Object Editing
- Raster/Vector Snapping
- Intelligent Object Picking/ Selection
- PDF Import/Export
- PDF Conversion to TIFF
If you are working with scanned paper drawings that have been saved as a .PDF or .Tif file format, then GTXRaster CAD® 2020 Series provides you with the most cost effective raster cleanup, raster editing or raster-to-vector conversion solution. When all you need to do is make a quick and simple change, whether its changing text or geometry in the drawing, GTXRaster CAD® 2020 Series will save you time and money, without the need to start from scratch.
GTX solutions are designed and developed for use in the following industries:
- Mechanical CAD (MCAD)
- Automated Mapping and Facilities Management (AM/FM)
- Architectural, Engineering and Construction (AEC)
- Geographical Information Systems (GIS)
- Power Generation, Oil and Gas
- Military
- Government
GTXRaster CAD® 2020 Series for BricsCAD V20 has been fully ported to the 64-bit platform and can run as a native 64-bit application directly on the Windows 10 x64 Edition, Windows 8/8.1 x64 Edition and Windows 7 x64 Edition.
With the latest licensing technology, users will benefit with the FLEXENABLED® Software licensing program -- using the FlexeraTM FLEXnet Publisher -- for either standalone single-user installation, or for multiple users with network installation.
Discover more 3rd party BricsCAD apps
GTXRaster CAD® 2020 Series and hundreds of other applications are available on the BricsCAD App Store.
Download BricsCAD free for 30-days
Start Using BricsCAD Today
Permanent or subscription licenses that work in all languages, in all regions.
