Dibujo 2D Modelado 3D
Customize Your BricsCAD Color Scheme
BricsCAD Dark Mode
Does BricsCAD have a dark mode? It's a question I get asked over and over again. For BricsCAD V20 the answer is yes!
Maybe you're a hardcore goth or maybe you just find a dark paper space less strain on the eyes. Well, today I'm going to show you how to not just get a dark paper space, but get literally every color combination you could wish for. But in the future, who knows. ;-), maybe we have something up our sleeves.
In this post I'm going to assume you're already au fait with the layout and settings for BricsCAD, if you're not, then I suggest you check out Hedi's posts on the interface and settings.
Paper space
Taking the paper space to dark mode is super easy.
paper black - BricsCAD
  1. First, let's open up the settings panel.
  2. Program options-Display-Paper space background color. For this example I chose black but you can choose any color you like!!
    paper space
3D view
light to dark
Change your workspace from light to dark
To get a dark mode feel in BricsCAD 3D Viewer:
  1. The background is customizable as part of the Visual Styles. You can create your own.
  2. First, enter the weird and wonderful world of the** Drawing Explorer** and navigate to the visual styles bar.
  3. Create a new view.
  4. Name, as you like.
  5. Select the settings you want and make sure that Backgrounds: Off!dark mode viewstyle
  6. Now navigate back to the Settings panel
  7. Program options-Display-Background color
    background colour
  8. Here I chose grey, but you can choose any color you like, honestly, go nuts.
subtle
The command line
Once you've changed the background color, you might find that the command line has too high contrast with the background. No problem. Simply go to Settings/Program options/User preferences/Command line.
You can change the background and text color of the command line list and the input areas individually.
commandline
In this example, I have chosen a black background with green and blue text, but you can use whatever settings you like!
The axis colors
The more eagle-eyed of you will have spotted that my Quad and axes are also custom colored. This is just as easy to change.
Program options-Display-X axis color/Y axis color/Z axis color.
Line weight
fat darkmode-1
Make line super fat or superfine
Ok so, now we've left you in the dark maybe there are other things you'd like to change in BricsCAD to help with eye comfort.
  1. Line weight is also fully customizable
  2. Go back to the settings panel
  3. Drawing-Drafting-Display/Viewing-Lineweights
  4. For this post I chose:
    | Entity lineweight | Default |
    | Default lineweight | 0.53 |
    | Lineweight display | yes |
    But you can mix and match the line weight to what suits you best.
  5. You will then need to go to the properties panel.
  6. Choose Lineweight: default. However, you can also change each line to suit per layer or per item, it's completely up to you. The same is true for color.
Does it have to be dark?
So now you know how to get the dark view, why not experiment and go crazy? See how far you can push BricsCAD! Feel free to send me your wildest creations.
go cazy
Go Wild! See what you can come up with.
23 de noviembre de 2022 5 min
How Technology Can Overcome the Top Challenges in Construction
New technology solutions continue to improve productivity and efficiency on construction sites around the world. However, upgraded design software can only push these improvements so far. To truly overcome the construction industry’s top challenges, the sectors’ professionals - architects, engineers, contractors and building owners - must embrace innovative solutions that provide the tools for stronger and better collaboration.
Leer más
22 de noviembre de 2022 4 min
Bricsys Digital Summit: BricsCAD V23 Spotlight – Great CAD productivity with amazing user experience
In this blog, we look at the features in Version 23 which are intuitive to use, learn and adopt when our users draft and design in their CAD workflows. This amazing user-experience is driven by the way our development teams harness new technology, so we’ll also highlight our favourite tools and commands to give users extra productivity too.
Leer más
Síganos en las redes sociales
blog-facebook-icon
blog-twitter-icon
blog-instagram-icon
blog-youtube-icon
blog-linkedin-icon
Esto es Bricsys
Bricsys, parte de Hexagon, es la compañía tecnológica global que crea la familia BricsCAD® de productos de diseño asistido por ordenador y la plataforma de colaboración de proyectos Bricsys 24/7.
© 2022 Bricsys NV. All rights reserved.
Part of hexagon
