Dibujo 2DModelado 3D
Working Smarter with BricsCAD Pro – The OPTIMIZE command
Por The Bricsys Team 4 min 22 de mayo de 2023
We have given the OPTIMIZE command a UI overhaul both for 2D and 3D designs. OPTIMIZE calculates the gap tolerance to close the gaps, fix inaccuracies in the drawing, and works in both 2D and 3D spaces. Let's take a look!
Checking drawing details
In this example you can see that there are many gaps between lines, or the lines are skewed and tilted.
OPTIMIZE BricsCAD Line Gaps
You can check how tilted a line is by viewing the properties panel. In this example, some objects are close to a rounded value, but they aren't actually rounded.
It's clear that we will have a lot of work on this drawing to make it workable and to make it more accurate. So, OPTIMIZE to the rescue!
Preview the drawing
OPTIMIZE improves many aspects of the drawing. You can preview these improvements by clicking the preview button to give you a full understanding of what will happen once you optimize the drawing.
Once you have checked the preview, you can see where you may need to tweak the settings to fix any remaining skewed lines or gaps which haven't closed to get a better result.
OPTIMIZE Preview BricsCAD
Optimize Settings
You will need to decide how big you want the gaps to be to close. BricsCAD has a new picker which lets you specify two points in the drawing, from which it calculates the gap tolerance. Any gaps closer than this tolerance will be closed.
OPTIMIZE BricsCAD Gap tolerance
This is visualized in your drawing with red circles.
Optimize Command Visualisation
You can also change the angle tolerance to optimize lines and change the rounding tolerance to one edge. This will close more gaps and rectify more skewed lines. Check the properties panel to see how the end points of the line are optimized to the closest integer.
Individual Optmization
The options in the OPTIMIZE command can also be used individually thanks to the command's new dash UI. Take for example this drawing of The Belfry in Bruges, Belgium. In reality, the building does not consist of straight lines – but there are still some inaccuracies that need to be fixed.
Once OPTIMIZE has calculated the initial possible optimizations, you can see the command panel launches.
Optimize Command Panel
Here, red circles indicate the size of the gaps that need to be closed.
Optimize BricsCAD
You can check the gap size to see if you are happy with it and change it if needed. Then, you can single click to see that these inaccuracies have been resolved.
Otimize for 3D
OPTIMIZE has undergone the same UI overhaul for 3D as in 2D, with settings logically grouped together. Let's now look at a 3D example.
OPTIMIZE Coplanar faces 3D BricsCAD
You can see that some of the faces of these solids are not optimal. Here you can see the slope of this face is 0.12 instead of 0.
Optimize 3D BricsCAD
When looking at the front, you can see that certain faces are not fully coplanar.
For this example, let's say that you only want to straighten faces which are parallel to the XY plane. You can check in the properties panel that the slope of all these faces is exactly 0.
Here you can see that these faces are still not coplanar. To fix this, you can use OPTIMIZE again, choosing the “Align parallel faces” option, you can also round them. After doing this and selecting multiple faces, you can now see that the slope is 0 and that the UCS elevation is exactly the same.
OPTIMIZE Align Parallel Faces BricsCAD
Watch the Video
Check out the YouTube walkthrough to watch the OPTIMIZE command in action!
Have you tried the OPTIMIZE command and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to let us know what you think about BricsCAD is to send us a support request, and our support team will be happy to help.
¿Quiere más consejos y trucos de BricsCAD?
Si tiene curiosidad sobre qué más puede hacer en BricsCAD, consulte nuestro canal de YouTube donde puede obtener más información sobre las funciones y los comandos de BricsCAD, o eche un vistazo al resto del blog de Bricsys.
15 de mayo de 2023 7 min
Artificial Intelligence in BricsCAD® Lite & Pro – What's the Point? Checking drawing health
In the previous blog post, we explained how automation and artificial intelligence are baked into key processes in BricsCAD® BIM to speed up your building design workflows. At Bricsys, we apply similar techniques across our BricsCAD® product portfolio, so we take the same approach with our flagship products BricsCAD® Lite and BricsCAD® Pro.
Síganos en las redes sociales
