Dibujo 2D
5 Ways to Edit a Polyline in BricsCAD - Tuesday Tips
Por Rose Barfield 4 min 20 de septiembre de 2021
When you start a new CAD drawing, the first thing you'll probably want to do is draw a line and the second you've done it, you'll probably want to edit that line! The good news is that whether you're adding a new vertex or editing the bulge value, BricsCAD® gives you plenty of ways to edit a line or a polyline.
1) The Quad
Use the Quad to add a vertex to a polyline, adjust the bulge of a segment, delete a segment or stretch a segment.
5 Ways to Edit a Polyline in BricsCAD - quad
How to edit a polyline in BricsCAD using the Quad:
  1. Turn the Quad On.
  2. Move the cursor over the polyline.
  3. Hold Ctrl.
  4. Move the cursor to the Quad and select a command.
  5. Edit the polyline.
2) PEDIT
Use PEDIT to edit vertices, convert segments between arc and straight, break a polyline, reverse the direction, insert and delete a vertex, change the width of a segment and convert splines into polylines.
5 Ways to Edit a Polyline in BricsCAD - PEDIT
How to edit a polyline with the PEDIT command in BricsCAD:
  1. Enter PEDIT.
  2. Select the polyline.
  3. Choose from the options.
  4. Follow the instructions in the Command line.
3) The Properties Panel
Use the Properties Panel to edit your polyline and get extra information, such as the number of vertices and the elevation. You can change the width and bulge of polyline segments to make the polyline closed, open, and more.
5 Ways to Edit a Polyline in BricsCAD - Properties-Browser
To edit a polyline with the Properties Panel:
  1. Select the polyline.
  2. Open the Properties Panel.
  3. Use the options to edit the polyline.
4) Simplify
Sometimes polylines become more complex and memory-intensive than you would like. Use the SIMPLIFY command to reduce the complexity of a polyline.
5 Ways to Edit a Polyline in BricsCAD - Simplify
How to reduce the complexity of a polyline in BricsCAD with SIMPLIFY:
  1. Enter SIMPLIFY.
  3. Choose your tolerance options in the Command line.
5) With commands
Use commands such as TRIMEXTEND and JOIN (which do exactly what they say on the tin) to edit polyline lines.
5 Ways to Edit a Polyline in BricsCAD - trim
How to trim a polyline in BricsCAD:
  1. Enter TRIM.
  2. (Optional) Select cutting entity/entities.
  3. Click the line to be trimmed. The section will be deleted to the nearest cutting entity.
  4. (Optional) Hold Shift to extend instead of trim.
5 Ways to Edit a Polyline in BricsCAD - extend
How to extend a polyline in BricsCAD:
  1. Enter EXTEND.
  2. (Optional) Select boundary entity/entities.
  3. Click the line to be extended. The section will be extended to the nearest cutting entity.
  4. (Optional) Hold Shift to trim the line instead of extend.
5 Ways to Edit a Polyline in BricsCAD - join
How to join polylines in BricsCAD:
  1. Enter JOIN.
  2. Select the entities to be joined.
  3. Press Enter.
    Note: polylines must be touching.
How else do you edit polylines in BricsCAD?
JOIN.
Know any ways that I have missed off the list? Let me know in the comments below.
Happy CADing!
Explore BricsCAD
Rose Barfield
por Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose es responsable de recibir los comentarios de los usuarios y mejorar el producto BricsCAD. Antes de llegar a BricsCAD, era usuaria de CAD y trabajó en las industrias automotriz, aeroespacial y de defensa como ilustradora técnica. Le encanta descubrir cómo funcionan las cosas, desmontarlas y (con suerte) volver a montarlas.
15 de abril de 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 de abril de 2024 4 min
In V24.2, we've further enhanced BricsCAD's DWG compatibility to ensure the rapid creation of design documentation by focusing on the 2D drawing creation workflow. To create the smoothest collaboration, we've ensured you can open and edit the drawings you create in BricsCAD in other DWG-based CAD programs. Let's dive into the enhancements we've made!
25 de marzo de 2024 4 min
Síganos en las redes sociales
