Parabuild is a steel detailing software to help you build 3D models of all types of structural steel, with the required BIM data. It allows you to automatically produce the drawings and files needed to fabricate and erect a structure, directly from the model.
It has an intuitive user interface which makes it easy to use and easy to learn. All connections are defined in constraint-driven, parametric drawings. This allows you to modify existing connections and create your own.
Once the model is complete, fully dimensioned workshop drawings and BOMs (Bills of Materials) can be created automatically.
Create CNC output at the click of a button, with many options to suit the machines you have, including advanced time-saving scribing options.
You can download it on the BricsCAD® App Store.
Start Using BricsCAD Today
Permanent or subscription licenses that work in all languages, in all regions.
