Dokumenten-Verwaltung
View 2D & 3D CAD files online with Bricsys 24/7
Von Rose Barfield 3 min 15. August 2019
Bricsys 24/7 allows you to view 3D files online, in your browser. Thanks to Bricsys 24/7's built-in 3D viewer, every person working on a project can open, explore, and annotate 3D models whenever they need to, even without CAD software installed on their machine. This includes all BricsCAD native .dwg files.
If you are looking for a way to view .dwg files for free check out BricsCAD ShapeODA's online .dwg converter
CAD file types supported by Brisys 24/7's online viewer:
  • dwg
  • dwf
  • dwfx
  • dxf
  • dgn
  • plt
  • hp
  • hpg
Bricsys 24/7 also provides full IFC (Industry Foundation Classes) support. Learn more about IFC.
Online viewer
You can upload, download, share, and view 3D models from your browser, without installing any software. There is also a direct connection from BricsCAD and BricsCAD BIM to Bricsys 24/7 so now it's even easier to share your files!
View 2D & 3D CAD files online with Bricsys 247- 3D viewer
No experience? No problem!
Bricsys 24/7 online 3D viewer is super easy to use, even with no experience working with CAD programs. Rotate and zoom in and out of the model, all from your browser. Use Bricsys 24/7's native tools to create a slice through the building. You can even add annotations to the models and you have full control over who can see the comments: keep them private, just share with the architect or make them viewable to everyone.
View 2D & 3D CAD files online with Bricsys 247- slice anotate
View BIM files in-browser
If you have projects with vast amounts of BIM data and plenty of associated documents, that's no problem. 24/7's model server manages all of the information required in a construction project.
It's easy to browse through a model's structure. Use the panel on the left-hand side of the screen to isolate an element and access any additional data related to that entity. You can query, merge, and filter the view depending on your individual needs.
View 2D & 3D CAD files online with Bricsys 247- structure
Full external reference file management
In addition, Bricsys 24/7 supports models using external references (XRefs). Bricsys 24/7 will recognize and automatically manage links between files.
XRefs allow a single file to reference other files and are typically used in large projects to keep down file sizes and allow people to work on different parts of a model at the same time. Learn more about XRefs.
More file types
Bricsys 24/7 doesn't just support .dwg and CAD files! It also offers in-browser support for over 70 different file types. Find the complete list of file types supported by Bricsys 24/7.
Ready to share your files online?
Find out more about Bricsys 24/7 at www.bricsys.com. Easy to try, easy to buy, easy to own. That's Bricsys. Try all of our products, for free for 30 days. You'll love what we've built for you with the Bricsys product family.
Rose Barfield
von Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose ist dafür verantwortlich, das Feedback der Benutzer aufzunehmen und das BricsCAD-Produkt zu verbessern. Bevor sie zu BricsCAD kam, war sie selbst CAD-Anwenderin und arbeitete in der Automobil-, Luftfahrt- und Verteidigungsindustrie als technische Illustratorin. Sie liebt es, herauszufinden, wie Dinge funktionieren, sie auseinanderzunehmen und (hoffentlich) wieder zusammenzusetzen.
15. April 2024 3 min
BricsCAD® Pro V24.2 - Leistungsverbesserungen
BricsCAD V24.2 ist da und bringt eine Reihe von Leistungsverbesserungen mit, die eine Steigerung der Effizienz und Stabilität versprechen. Die neueste Version ist auf technische Zeichner, Designer und Hersteller aller Branchen zugeschnitten und konzentriert sich auf die Beschleunigung der Erstellung detaillierter Designdokumentation, die für Bau-, Fertigungs- und Herstellungsprozesse unverzichtbar ist. Sehen wir uns die Verbesserungen in V24.2 genauer an, die Ihre Lieferzeit verkürzen werden.
8. April 2024 4 min
Verbesserte Zeichnungskompatibilität in BricsCAD® V24.2
In V24.2 haben wir die DWG-Kompatibilität von BricsCAD weiter verbessert, um die schnelle Erstellung von Designdokumentation zu gewährleisten, indem wir uns auf den Arbeitsablauf zur Erstellung von 2D-Zeichnungen konzentrieren. Um eine reibungslose Zusammenarbeit zu gewährleisten, haben wir sichergestellt, dass Sie die in BricsCAD erstellten Zeichnungen in anderen DWG-basierten CAD-Programmen öffnen und bearbeiten können. Schauen wir uns die Verbesserungen an, die wir vorgenommen haben!
25. März 2024 4 min
Was ist neu in BricsCAD® Lite und Pro V24?
Im neuesten Update bietet BricsCAD® V24.2 viele neue und verbesserte Funktionen, um die Erstellung Ihrer 2D-Zeichnungen zu vereinfachen. Wir haben eine intuitivere Benutzererfahrung eingeführt, die Leistung und Stabilität verbessert und neue und verbesserte Funktionen hinzugefügt, um Ihre Produktivität weiter zu steigern. Diese Version bietet Arbeitsabläufe, die die Präzision und Vielseitigkeit ermöglichen, die Sie für den reibungslosen Ablauf Ihrer 2D-Zeichnen- und Designprojekte benötigen.
Folgen Sie uns in den sozialen Netzwerken
