2D Zeichnen
Open - Foreign DWG File: AutoCAD Error Message
Von Rose Barfield 3 min 27. Juli 2020
Open - Foreign DWG File AutoCAD Error Message
When you open a .dwg file that was saved by a program that was not developed by Autodesk®, such as BricsCAD®, you might get the following error message: "Open -- Foreign DWG File | This DWG file was saved by an application that was not developed or licensed by Autodesk. What do you want to do?"
Keep reading to discover what's happening and what you should do next.
Can I still open my .dwg file in AutoCAD®?
Although this might seem alarming, don't worry. You and your clients can still open .dwg files in AutoCAD®, even if they were saved with alternative CAD programs, such as BricsCAD®.
If you're creating .dwg drawings outside of Autodesk®, it's a good idea to pre-warn people when you send them a file so they don't panic when they see the error message.
What to do next?
When the error message displays, click "Continue opening DWG file".
To stop the dialog box from displaying again, check the "Always open DWG files regardless of origin" option.
Open - Foreign DWG File AutoCAD Error Message- solution
Click "Continue opening the DWG file" and check the "Always open DWG files regardless of origin" box.
After the file opens, the Command line will display this message: "Non-Autodesk DWG. This DWG file was saved by a software application that was not developed or licensed by Autodesk. Autodesk cannot guarantee the application compatibility or integrity of this file."
Open - Foreign DWG File AutoCAD Error Message- command line error
Command line warning displays
Again, there is no need to panic. It's just an informational message.
Why does the "Foreign DWG File" error message display?
This error message displays because of the AutoCAD® DWGCHECK system variable.
The dialog provides you with information and is shown just in case Autodesk® cannot support the file. You will, however, find that AutoCAD® can typically help BricsCAD® files without issue. If you don't believe us, put BricsCAD® to the test!
If you're still unsure, check out this helpful Cadalyst article on the safety of dwg drawings.
How to open DWG files effortlessly
The good news is that BricsCAD® doesn't show you an error message when you open up a .dwg file, regardless of the application you used to save the drawing. BricsCAD® is highly compatible. We’re so confident of our compatibility that we urge you to put BricsCAD® to the test!
  1. Download the free, 30-day trial.
  2. Open up your .dwg drawings.
  3. If you're unhappy with the results, send us a support request, and our first-class support team will do its best to ensure that your drawings are up and running without the error.
Put BricsCAD® to the test!
Permanent or subscription licenses that work in all languages in all regions.
Download BricsCAD free for 30-days
Rose Barfield
von Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose ist dafür verantwortlich, das Feedback der Benutzer aufzunehmen und das BricsCAD-Produkt zu verbessern. Bevor sie zu BricsCAD kam, war sie selbst CAD-Anwenderin und arbeitete in der Automobil-, Luftfahrt- und Verteidigungsindustrie als technische Illustratorin. Sie liebt es, herauszufinden, wie Dinge funktionieren, sie auseinanderzunehmen und (hoffentlich) wieder zusammenzusetzen.
15. April 2024 3 min
BricsCAD® Pro V24.2 - Leistungsverbesserungen
BricsCAD V24.2 ist da und bringt eine Reihe von Leistungsverbesserungen mit, die eine Steigerung der Effizienz und Stabilität versprechen. Die neueste Version ist auf technische Zeichner, Designer und Hersteller aller Branchen zugeschnitten und konzentriert sich auf die Beschleunigung der Erstellung detaillierter Designdokumentation, die für Bau-, Fertigungs- und Herstellungsprozesse unverzichtbar ist. Sehen wir uns die Verbesserungen in V24.2 genauer an, die Ihre Lieferzeit verkürzen werden.
8. April 2024 4 min
Verbesserte Zeichnungskompatibilität in BricsCAD® V24.2
In V24.2 haben wir die DWG-Kompatibilität von BricsCAD weiter verbessert, um die schnelle Erstellung von Designdokumentation zu gewährleisten, indem wir uns auf den Arbeitsablauf zur Erstellung von 2D-Zeichnungen konzentrieren. Um eine reibungslose Zusammenarbeit zu gewährleisten, haben wir sichergestellt, dass Sie die in BricsCAD erstellten Zeichnungen in anderen DWG-basierten CAD-Programmen öffnen und bearbeiten können. Schauen wir uns die Verbesserungen an, die wir vorgenommen haben!
25. März 2024 4 min
Was ist neu in BricsCAD® Lite und Pro V24?
Im neuesten Update bietet BricsCAD® V24.2 viele neue und verbesserte Funktionen, um die Erstellung Ihrer 2D-Zeichnungen zu vereinfachen. Wir haben eine intuitivere Benutzererfahrung eingeführt, die Leistung und Stabilität verbessert und neue und verbesserte Funktionen hinzugefügt, um Ihre Produktivität weiter zu steigern. Diese Version bietet Arbeitsabläufe, die die Präzision und Vielseitigkeit ermöglichen, die Sie für den reibungslosen Ablauf Ihrer 2D-Zeichnen- und Designprojekte benötigen.
Folgen Sie uns in den sozialen Netzwerken
