Desenare 2DModelare 3D
Printing in BricsCAD – Layouts
De Kelsey Grant 3 min 21 februarie 2022
When printing in BricsCAD, there are two main interfaces to explore: Model Space and Paper Space. Model Space is a black screen wherein you create your 2D drawings and 3D models. In Paper Space we create layouts and are typically used to organize drawings for hard copy or soft copy printing.
When you open BricsCAD, you can see three tabs at the bottom of the workspace. By default, you will be in the Model Space. You can see the model tab is active and you can switch over to Paper Space by clicking on any of these layout tabs.
BricsCAD Layouts tabs - GIF
Next, you can select the 'Layout 1' tab to switch over to the Paper Space. This white screen is a representation of a sheet of paper where you can see your drawing opened in a viewport.
A viewport is an entity on the layout and is a window to the Model Space. Each layout can have a different paper size and varied properties such as plot style, table drawing orientation,  printer configuration, etc. You can select the right layouts to properly communicate your unique design.
BricsCAD Layouts select - GIF
Let's change the properties of Layout 1. To do this, you'll need to right-click on 'Layout 1' and click on 'Page setup'. In the printer plotter configuration, you will get a pop-up list in which different plotters are listed. Click on 'Print as pdf' to get a pdf soft copy output, and in the paper size popup choose a suitable paper size depending upon your requirements. Here we've clicked on 'iso A3' to plot to an A3 size paper. You can change the units to inches or millimeters. We've selected millimeters and a plot scale of 1:1.
Next, you'll need to click on the plot style table pop-up and choose 'Default.ctb'. Select 'Landscape' to get a landscape drawing orientation, and then select 'OK'.
BricsCAD Layouts style layout - GIF
To finish, you'll click on 'Layout 2', right-click and go to 'Page setup'. Here you can change the parameters of this layout. You can create as many layouts as you want by clicking on the plus sign. To rename a layout, right-click on the layout tab and select the 'Rename' option to give your layout a suitable name.
To delete a layout you'll need to right-click on the layout tab and select the 'Delete' option.
BricsCAD Layouts - delete layout GIF
Now you know the basics of printing, the different layouts in BricsCAD, and how you can use them to navigate and communicate your unique design! If you'd like to know more, you can view the full video.
Learn more about Paper Space in BricsCAD:
Kelsey Grant - Author
de Kelsey Grant - Marketing Content Specialist
LinkedIn logo (b&w)
Kelsey este specialistul nostru în conținut de marketing la Bricsys, cu sediul în Marea Britanie. Venind de la o experiență în Social Media la CAD, ea se mândrește cu crearea de conținut clar și captivant, ajutând să ghideze utilizatorii BricsCAD să creeze lucruri grozave!
15 aprilie 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 aprilie 2024 4 min
Compatibilitate îmbunătățită a desenelor în BricsCAD® V24.2
În V24.2, am îmbunătățit și mai mult compatibilitatea DWG a BricsCAD pentru a asigura crearea rapidă a documentației de proiectare, concentrându-ne pe fluxul de lucru pentru crearea desenelor 2D. Pentru a crea cea mai bună colaborare, ne-am asigurat că puteți deschide și edita desenele pe care le creați în BricsCAD în alte programe CAD bazate pe DWG. Haideți să ne aruncăm în îmbunătățirile pe care le-am făcut!
Urmărește-ne pe rețelele sociale
