Sfaturi 2D
Find & Replace text in BricsCAD - Tuesday Tips
De Rose Barfield 4 min 3 august 2020
Find & Replace - Tuesday Tips
The FIND (Ctrl+F) command lets you find, zoom to and replace text in BricsCAD®. You can search for text in blocks, attributes, dimensions, and hyperlinks. It works the same way as the Find & Replace tool on a word processor.
To find and replace text in BricsCAD, you can use the "Find and Replace" tool:
  • Type "FIND" in the command line or select "Find and Replace" from the "Express" menu.
  • In the "Find and Replace" dialog box, enter the text you want to find in the "Find" field.
  • Enter the text you want to replace within the "Replace with" field.
  • Specify the search options, such as case sensitivity and the search scope.
  • Click "Replace All" to replace all occurrences of the text or "Replace" to replace only the current selection.
  • Note: The "Find and Replace" tool in BricsCAD can also find and replace text in attributes and tables.
How to Find Text
Finding text in a drawing in BricsCAD is simple:
  1. Enter Find.Find & Replace - Tuesday Tips- dialog
  2. (Optional) Set the Find and Replace options.Find & Replace - Tuesday Tips -options
  3. Type the text to search for in the Find Text String box.
  4. (Optional) Click the Select Entities button to compose a selection set. The Find and Replace dialog will temporarily close to let you select entities. Once you have finished, hit Enter. The Search in field will now read Current Selection instead of Entire Drawing.
  5. Click the Find Next button. The content of the first text entity that contains the search string is displayed in the Search results pane.
  6. (Optional) Click the Zoom To button.
  7. Hit Esc or click the Close to stop.
NOTE
Only text entities in the selection set are searched if a selection is active when you launch the FIND command.
How to Replace Text
You can find and replace text one by one or all matching entities in one go.
  1. Enter Find.
  3. Type the search text in the Find Text String field.
  4. Type the replacement text in the Replace with: field.
  5. (Optional) Click the Select Entities button to compose a selection set.
    • The Find and Replace dialog temporarily closes to let you select entities.
    • Right-click to conclude the selection of entities.
  6. Click the Replace All button to replace all matching text.
    OR
    Click the Find Next button. The content of the first text entity that contains the search text is displayed in the Search results pane.
    1. (Optional) Click the Zoom To button.
    2. Click the Replace button.
    3. Repeat this step to find another text entity that contains the search string. Repeat until you have made all the required changes.
Get started with BricsCAD today
Permanent or subscription licenses that work in all languages in all regions.
More Tuesday Tips:
Rose Barfield
de Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose este responsabilă pentru preluarea feedback-ului utilizatorilor și îmbunătățirea produsului BricsCAD. Înainte de a veni la BricsCAD, ea a fost ea însăși utilizator CAD și a lucrat în industriile auto, aerospațială și de apărare ca ilustrator tehnic. Îi place să afle cum funcționează lucrurile, să le descompună și (sperăm) să le pună din nou împreună.
15 aprilie 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 aprilie 2024 4 min
Compatibilitate îmbunătățită a desenelor în BricsCAD® V24.2
În V24.2, am îmbunătățit și mai mult compatibilitatea DWG a BricsCAD pentru a asigura crearea rapidă a documentației de proiectare, concentrându-ne pe fluxul de lucru pentru crearea desenelor 2D. Pentru a crea cea mai bună colaborare, ne-am asigurat că puteți deschide și edita desenele pe care le creați în BricsCAD în alte programe CAD bazate pe DWG. Haideți să ne aruncăm în îmbunătățirile pe care le-am făcut!
Urmărește-ne pe rețelele sociale
