3D 建模 2D 製圖 BIM
BricsCAD® BIM V24: Quickest path to 3D from 2D
By The Bricsys Team 5 分鐘 2023年12月14日
With BricsCAD® BIM V24's new modeling tools, you can transition from a 2D plan to a 3D model and convert your design concepts into 3D representations quickly and easily! With V24, you can pull 2D plans into 3D to create solid objects, better identify structures and entities with Top View mode, and convert everything into a complete BIM project.
Let's walk through how you can go from 2D to 3D in a flash with BricsCAD BIM V24.
Attach 2D plan to 3D model in BricsCAD®
BricsCAD 2D plan to 3D model
When you receive a 2D plan from a designer, you can attach it to a 3D model, so when you receive an updated version, all you need to do is update the link. Once you have the plan attached, you can begin modeling!
Exterior Walls
External walls BricsCAD BIM
In this example, we start by adding exterior walls in Top View Mode. You can access Top View mode from the story bar. We used a poly wall with the wall tool, inserted the relevant details like height, thickness, and justification, and traced the walls with the simple snap-on.
Interior Floor Layout
BricsCAD BIM Slab tool floor
Now that our exterior walls are in place, we can move on to the floor. Using the new slab tool, you can easily create a floor slab. If you navigate the Home tab, you'll find easy access to model any shape you need. Select the slab tool, identify the justification, select all entities, and create the slab. Then, you can assign an offset to extend the slab under the external wall.
Automatic Boundary Detection for Columns
Boundary Detection Column BricsCAD BIM
BricsCAD's column tool supports most standard generic shapes for steel and concrete, and you can access them from the library. You can even choose a non-square profile and use boundary detection to identify the columns.
Interior Walls and Doors
Interior Wall BricsCAD BIM
To complete the interior floor's layout, you can add a single wall segment using the wall tool and choosing a single wall. You can assign an internal wall composition from the library. This tool recognizes wall thickness and gives you the option to automatically adjust its angle based on a 2D line. This smart behavior can also be used with point cloud data. You can swap the direction using the control button for a better interpretation. Then, you can use the BIM Extend tool to finish the wall.
Interior Doors BricsCAD BIM
Once you have finished with the walls, you can begin placing the doors and windows. You can change the visualization to see-through and see the 2D plan to fit the entities in the correct location. From the BricsCAD library, you can choose the doors that best fit your project, and the Quad makes it easy to flip the door or change its direction as needed.
Flip Door BricsCAD BIM
IFC Classification in BricsCAD®
IFC Classification BricsCAD BIM
BricsCAD allows you to either start with known materials and predefined parameters, or with only the geometry. Our automatic classification carries out the IFC classification on all elements - speeding up your process further.
New Roof Tool in BricsCAD® BIM V24
Roof BricsCAD BIM
The QUICKDRAW command allows you to create more floors with the same shape and content, or only create the external walls, and place the final slab for the roof. You can stick to a flat roof, or if you want to use a standard roof shape like a gable, or M-shape you can use the new roof tool to quickly insert the roof you need.
M Shape Roof BricsCAD BIM
In BricsCAD BIM V24, we have added building modeling tools that are familiar, easy to use, and smart when needed. You can move from a 2D plan to a 3D model quickly to visualize your design concepts more tangibly and identify potential design flaws, clashes, or ways to improve the process.
Watch the tutorial!
To follow along with a video tutorial, you can watch this session on the Bricsys YouTube channel.
There's plenty more in BricsCAD BIM V24, so watch our Breakout Sessions for an in-depth look at some of these new features!
Want to learn more about BricsCAD® V24?
If you're curious about what else you can do in BricsCAD V24, check out our YouTube channel or take a peek at the rest of the Bricsys blog to learn more!
Have you used BricsCAD® V24 and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to tell us what you think about BricsCAD is to send us a support request; our support team will gladly help.
Get started with BricsCAD® V24 today!
Buy BricsCAD or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
2023年12月7日 1 分鐘
BricsCAD® V24 - 現代化的使用者體驗
如果您是已移轉到 BricsCAD 的 CAD 用戶,即使是微小的差異也會讓您感到不適應。為了協助您進行轉換,我們在 BricsCAD 中直接加入了產品內指導。有了經過改進的起始頁,您會發現選擇樣板、最近開啟的圖面清單以及將最近使用的檔案固定到清單頂部的選項都非常簡單。
2023年11月16日 2 分鐘
BricsCAD® V24:BricsCAD® BIM 的新功能?
我們希望透過 BricsCAD® BIM V24 為您提供所需的工具。我們的許多用戶至少有 40%-50% 的專案從設計師那裡獲得 2D 圖面,因此他們需要將 2D 圖面轉換為 3D 和 BIM 模型,以便進行視覺化、協調、規劃和工程量計算。BricsCAD BIM V24 的工具讓這種轉換變得更加簡單,這些工具易於使用、熟悉,並在需要時具有智慧性。
2023年11月2日 2 分鐘
BricsCAD® V24:Lite 和 Pro 的新功能?
歡迎使用 BricsCAD® V24 - 功能強大、高效易用的 CAD 軟體,該軟體旨在簡化您的工作流程並加快交付時間。BricsCAD® V24 比以前的 BricsCAD® 版本更快、更高效,而且用戶介面更加友好,是 CAD 新老使用者的完美工具。該版本包括 BricsCAD® Lite 和 BricsCAD® Pro 的功能和增強功能,可自動優化日常工作流程。讓我們深入瞭解 BricsCAD® Lite 和 BricsCAD® Pro 在 V24 中的新功能!
在社交媒體上關注我們
