2D Drafting 3D Modelling
DWTs - why you should be using them - Tuesday Tips
By Rose Barfield 3 min 28 september 2020
DraWing Template files (DWTs) set certain drawing aspects: layers, text styles, units, etc. Creating a DWT means you only need to set your preferences once.
What is a drawing template (DWT)?
A template describes the settings for your drawing. Use templates to save style settings for layers, text styles, units, view style and etc.
How to save a drawing template?
To save a drawing template:
  1. Set all your preferences and settings exactly the way you want. For me this meant changing the facets, the view style, the units and the grid visibility.
  2. Enter SaveAs.
  3. Select the Drawing Template (.dwt) option.
  4. Enter a sensible name.
  5. For easy access save it to the Templates folder: C :\Users\ USER_NAME \AppData\Local\Bricsys\BricsCAD\V20x64\en_US\Templates.
    Use the TemplateFolder command to locate the file path quickly on your computer.
How to access a drawing template?
To access a saved dwt file:
  1. Launch BricsCAD.
  2. On the start page, on the top-left corner there is a blue box with a +. Below it is a drop-down menu with the text "Template...". Click this.DWTs - why you should be using them- start page
  3. Choose the template you require from the drop-down menu.DWTs - why you should be using them- template-options
Can't find your DWTs?
Make sure that your .dwt file is saved to the Templates folder: C :\Users\ USER_NAME \AppData\Local\Bricsys\BricsCAD\V20x64\en_US\Templates.
Can I open my AutoCAD® DWT files with BricsCAD®?
Yes you can open  AutoCAD® DWTs with BricsCAD! Things like layers, grid and units transfer over effortlessly, so there is no need to worry about creating lots of new files if you switch to BricsCAD.
In fact, we encourage you to test it for yourself:download the 30-day, free trial and open your existing drawing templates and .dwg files in BricsCAD. You'll be impressed at how quickly you can be up and running. If you're not happy with the results, send us a support request and we'll do everything we can to make your transition to BricsCAD effortless.
More Tips:
15 april 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 april 2024 4 min
In V24.2, we've further enhanced BricsCAD's DWG compatibility to ensure the rapid creation of design documentation by focusing on the 2D drawing creation workflow. To create the smoothest collaboration, we've ensured you can open and edit the drawings you create in BricsCAD in other DWG-based CAD programs. Let's dive into the enhancements we've made!
25 mars 2024 4 min
Follow us on social media
