Modelare 3D
How to Model a 3D Chick - Easy Builds
De Rose Barfield 5 min 1 aprilie 2021
How to Model a 3D Chick – Easy Builds
In this series, you will learn how to work with CAD, by following easy projects. Use only simple commands to build almost anything! For this tutorial, learn how to model a 3D chick.
Watch the video on YouTube
How to Model a 3D Chick in BricsCAD
Time to complete: 45 mins
Difficulty: 7/10
Commands used:
COPY
DMDEFORMPOINT
DMTHICKEN
DMSTITCH
EXTRUDE
FILLET
LCONNECT
LINE
LOFT
MANIPULATE
MIRROR
REGION
SPHERE
SPLINE
Tutorial: Model a 3D Chick in BricsCAD
  1. In the Properties panel, change the Visual style to Conceptual.How to Model a 3D Chick – Easy Builds- 1 cocept
  2. Draw a horizontal LINE, this will be useful as a center point later.How to Model a 3D Chick – Easy Builds- 1 line
  3. Draw a SPLINE with a slight curve to it (see image). Use the first line as a starting point. How to Model a 3D Chick – Easy Builds- 2 spline
  4. Use DMTHICKEN to convert the spline into a 3D solid. It should look like a bent cylinder and will become the body of the chick. How to Model a 3D Chick – Easy Builds- dmthicken
  5. FILLET the edges. How to Model a 3D Chick – Easy Builds- 5 fillet
  6. In the Properties panel, change the layer color to yellow.How to Model a 3D Chick – Easy Builds- 6 colour
  7. Draw a SPHERE towards the top of the body. This will become the head. How to Model a 3D Chick – Easy Builds- 7 sphere
  8. Use a SPLINE to draw a wing shape. Make sure that the spline is closed. How to Model a 3D Chick – Easy Builds- 8 spline
  9. Use REGION to convert the spline into a region. How to Model a 3D Chick – Easy Builds- 9 region
  10. COPY  the region. Keep it in exactly the same location.
  11. Use DMDEFORMPOINT to deform the top region into a curved, wing shape. How to Model a 3D Chick – Easy Builds- 11 deform
  12. Use DMSTITCH to convert the 2 regions into 1 solid.
    Tip: If you can not complete steps 9 -- 12 you can simply EXTRUDE  the spline and then FILLET the edges.
  13. Use the Manipulator to move the wing into position and rescale it, if required. How to Model a 3D Chick – Easy Builds- 13 manipulator
  14. Use LINE to draw a three-pointed chicken foot shape. How to Model a 3D Chick – Easy Builds- 14 foot
  15. Use LINE to draw a vertical "leg". How to Model a 3D Chick – Easy Builds- 15 leg
  16. Use DMTHICKEN to convert the lines into solids. How to Model a 3D Chick – Easy Builds- 16 thicken
  17. EXTRUDE the end of each toe at an angle.
    Tip: Use Tab to switch between the length and angle dynamic input boxes. How to Model a 3D Chick – Easy Builds- 17 extrude
  18. Use LCONNECT to connect the toes at the back of the foot. How to Model a 3D Chick – Easy Builds- 18 lconnect
  19. Use the Manipulator to move the leg into position, relative to the foot. How to Model a 3D Chick – Easy Builds- 20 manipulate
  20. FILLET the edge of the leg. How to Model a 3D Chick – Easy Builds- 20 fillet
  21. Use the Manipulator to move the leg into position and rescale it, if required. How to Model a 3D Chick – Easy Builds- 19 manipulator
  22. MIRROR the leg and the wing. How to Model a 3D Chick – Easy Builds- 22 mirror
  23. Reposition the legs, as required. How to Model a 3D Chick – Easy Builds- 21 manipulator
  24. Use SPLINE to draw the top and side profile of a beak.
    How to Model a 3D Chick – Easy Builds- wireframe break-800x591
If you like, you can download this image, import it into BricsCAD and trace it. Note: all lines are broken at meeting points.
__Tip:__ If you find this too complicated, make a cylinder and taper it to a point.
  1. LOFT between the splines to create a beak. How to Model a 3D Chick – Easy Builds- loft
  2. Use XEDGES  to extract the edges of the surfaces at the back of the beak.
    Tip: Use Tab on hover to toggle the selected entity.
    How to Model a 3D Chick – Easy Builds- 26 edges
Edges show in blue.
  1. LOFT between the splines to create two surfaces that cover the back of the beak. How to Model a 3D Chick – Easy Builds- surface
  2. Use DMSTITCH to convert the 6 regions into 2 solids.
  3. Use the Manipulator to move the beak into position and scale as required. How to Model a 3D Chick – Easy Builds- 28-manipulator
  4. Use SPHERE to draw an eye on the head. How to Model a 3D Chick – Easy Builds- 30 eye
  5. MIRROR the eye. How to Model a 3D Chick – Easy Builds- 30 mirror
  6. Use the Structure Browser to hide any unwanted entities in the drawing. How to Model a 3D Chick – Easy Builds- 31 stucture
  7. Use the Properties panel to change the color of the chick.How to Model a 3D Chick – Easy Builds- 32 colour
If you have completed all the above steps correctly, you should now have something like this:
How to Model a 3D Chick – Easy Builds- moneyshot
Happy CADing!
Download BricsCAD free for 30-days
Get started modeling a 3D chick in BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
Enjoy this project?
Why not try some other easy builds?
19 martie 2024 9 min
Ce este nou în BricsCAD® V24.2
BricsCAD® V24.2 este plin de caracteristici noi și îmbunătățite pentru desenul 2D, modelarea 3D, civil, topografie, BIM și fluxuri de lucru mecanice. Cu această versiune, echipa Bricsys a inclus mai multe caracteristici noi și îmbunătățiri pentru a vă ajuta să accelerați timpul de livrare și pentru a vă oferi o experiență CAD familiară. Așadar, haideți să ne aruncăm și să explorăm noutățile din BricsCAD V24.2!
10 martie 2024 6 min
Calea către automatizarea Scan to BIM cu BricsCAD® BIM V24
Noile instrumente de automatizare incluse în BricsCAD® BIM V24 fac procesul Scanare-către-BIM mai ușor și mai eficient! Dacă doriți o captură rapidă și precisă a realității obiectelor existente, aceste instrumente vor fi o completare excelentă a arsenalului dumneavoastră. Am adăugat instrumente precum Clasificator Nor Puncte, Detectare Camere Nor Puncte, Potrivire Camere Nor Puncte și Calcul Normal pentru norii de puncte structurați, pentru a vă ajuta să creați gemeni digitali pentru preluarea cantităților, să creați planuri de construcție precise și pentru gestionarea instalațiilor.
3 martie 2024 7 min
Desenați managementul sănătății cu BricsCAD® V24
Când lucrați la un model 3D, este esențial să vă asigurați că modelele dvs. sunt optimizate pentru performanță și eficiență mai bune! Acest lucru este ușor de realizat cu ajutorul instrumentelor de gestionare a stării de sănătate a desenelor din BricsCAD. Citiți mai departe pentru a afla cum puteți optimiza modelele 3D de mari dimensiuni și reduce dimensiunea fișierelor în BricsCAD V24.
Urmărește-ne pe rețelele sociale
