Desenho 2D
BricsCAD: Discover the Difference: Better Drawing Management with Drawing Explorer
Por Gavin England 3 min 9 de agosto de 2022
Drawing Explorer A Single Tool
In today’s review of ‘BricsCAD: Discover the Difference’, we’re going to look at how Drawing Explorer offers a simple tool for comprehensive drawing management. Ever more people are replacing their legacy dwg-based CAD systems to enjoy greater productivity with BricsCAD for better value. Let’s explore how.
When you need to manage large or complex drawings, often from multiple stakeholders, the Drawing Explorer in BricsCAD provides a fast and effective way to control many different aspects of a drawing in a single tool.
Large, complex drawings to CAD – simply drag and drop precise layers
The Drawing Explorer enables all the key aspects of a drawing to be managed in one singular and comprehensive place, providing holistic visibility of the properties within the drawing. Drawing Explorer is a fast, effective way to configure any drawing, and the learning curve for new users isn’t steep because it’s only one single tool for users to become familiar with. And the BricsCAD tool is especially useful when managing large or complex drawings.
Let’s take an example. You might have a drawing submitted by a less-experienced user, and the quality doesn’t meet your CAD standards. For example, the layers might be there, but maybe the full details aren’t displayed correctly. With Drawing Explorer, you can drag and drop layers between two open drawings, and then simply copy and paste the correct layer definitions over the incorrect ones. This gives you precise control over your drawing.
Drawing Explorer Drag Drop Layers
Drag and Drop Block definitions – discover object definitions quickly
To further increase your productivity, it’s not just the layer definitions which you can drag and drop. You can also use the Block function to drag and drop between open drawings. And text styles, dimension styles, plus a lot more, can be defined with drag and drop Block function too. This greatly reduces the time and effort you will need to manage object definitions between drawings.
Drawing Explorer Reduce Time Spent Managing Object Definitions
The Drawing Explorer also lets you search for layers or discover differences between object definitions. It really is a single tool to manage and configure a drawing, and the tool even allows you to insert blocks directly from Drawing Explorer.
Drawing Explorer Single Tool Many Options
So, to manage multiple drawings in a unique, comprehensive tool, the Drawing Explorer gives you this power quickly and holistically. Your work will be more effective, and your project drawings will be more consistent.
Drawing Explorer Benefits
Drawing Explorer is just one of the unique, advanced and intelligent tools in BricsCAD. Keep a look out for the blog posts coming for more of these insights. And in the meantime, why not discover the BricsCAD difference in your work – simply download your free trial today (no commitment required).
Visit our migration page for more information on how easy it is to move to BricsCAD
19 de março de 2024 9 min
As Novidades no BricsCAD® V24.2
O BricsCAD® V24.2 está repleto de recursos novos e aprimorados fluxos de trabalho para desenho 2D, modelagem 3D, civil, topografia, BIM e Mecânica. Com essa versão, a equipe da Bricsys incluiu vários novos recursos e melhorias para ajudar você a acelerar sua entrega, e fornecer uma experiência CAD familiar. Então, vamos mergulhar e explorar o que há de novo no BricsCAD V24.2!
10 de março de 2024 7 min
O caminho para a automação de Scan para BIM com BricsCAD® BIM V24
As novas ferramentas de automação incluídas no BricsCAD® BIM V24 tornam o processo de digitalização (Scan-to-BIM) mais fácil e eficiente! Se você deseja uma captura rápida e precisa da realidade de objetos existentes, essas ferramentas serão um ótimo complemento para seu arsenal. Adicionamos ferramentas como o Classificador de Nuvens de pontos, Detectar Espaços em Nuvem de pontos, Ajustar Espaços em Nuvem de pontos e Cálculo da Normal para nuvens de pontos estruturadas, para ajudar você a criar gêmeos digitais para levantamento de quantidades, criar precisas plantas de construção, e fazer gerenciamento de instalações.
Siga-nos nas mídias sociais
