BIM
Point Cloud to a BIM Model - Modeling a Church - 2 Windows and Towers
Przez Fleur Dooms 3 min 27 lutego 2020
In this series, I will show you how to work with point clouds and how to trace and convert a point cloud to a BIM model. In my last post, I showed you how to create the walls and roof. In this post I will show you how I made the windows and the tower of the church using typical CAD commands.
Making the tower
I won't go into too much detail about how I made the tower of the church because you will probably have a different point cloud with a differently shaped church and tower.
How to Do This:
  1. Use the point cloud as a guide. Make a tower on the left side of the church. Use DmPushPullSliceSubtractUnion and Loft.  Use Loft with Guidelines to get the rounded shape.Point Cloud to a BIM Model -tower
  2. Use Shell to make the dome hollow. Select the lower face to be removed during the command. The section should look something like this:Point Cloud to a BIM Model -Picture20
    Tip: To make the smaller, domed roof scale down a copy of the larger domed roof.
Adjusting the buttresses and columns
I then adjusted the buttresses so that they had the correct heights and slope angle. To do this I used the Manipulator attached to a face.
How to Do This:
  1. DmPushPull the top of the buttresses to the lowest height. Use the point cloud as a guide.
  2. Select the top face, of each buttress, long click the mouse to get the Manipulator and rotate the faces until they are at the correct angle.
  3. Repeat as needed.Point Cloud to a BIM Model -Picture21
Adding windows
Next I created windows from polylines using BIMWindowCreate.
How to Do This:
  1. Set your UCS to a vertical face of a wall.
  2. Use Polyline and Arc to draw the contour of the window (Mirror the first arc, to get a symmetric result).Point Cloud to a BIM Model -Picture22
  3. Set Boundary detection to 'On'.
  4. Set your UCS back to 'World'.
  5. Hover over the boundary inside the window outline. Select BIMWindowCreate from the Quad and choose the 'Triptych' option. You should now have something that looks like this:Point Cloud to a BIM Model -Picture23
  6. Use BIMInsert to reuse this window. Hover over the window and select BIMInsert from the Quad.
  7. Repeat steps 1-5 to create other windows, with different sizes and shapes.
    Tip: You can re-use the polyline to create new windows of different sizes. Use copy and scale. To scale the polyline in a nonuniform manner convert it into a block, edit it and then explode the block. Use the polyline to create a new window.
    You should now have something like this:Point Cloud to a BIM Model -Picture24
The result so far might astonish you but be sure to come back for the last post in this Point Cloud to BIM series where I show you how to create the inner arcades and complete your church with a few finishing touches!
Download BricsCAD free for 30-days
Get modeling your Church in CAD with BricsCAD®
Permanent or subscription licenses that work in all languages, in all regions.
Point Cloud to BIM Model:
  1. The Outside
  2. Windows and Towers
  3. The Interior
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
