Modelowanie 3D
Get started with BricsCAD Shape - Joachim's Journey - Part 3
Przez Joachim Corijn 2 min 11 września 2019
Welcome back, on our last stop I showed you how to download and install BricsCAD Shape. This week, let's get started with BricsCAD Shape!
The first thing you'll notice when you launch BricsCAD Shape is the Get Started screen. The Get Started screen has 2 tabs: Home and Learn. I'll introduce you to these from the top-down.
Home
Get started with BricsCAD Shape - Joachim-s Journey -landing page-e1572273419576-1024x578
The Home tab is where you launch into BricsCAD Shape and start your design. Here you can open previous drawings, create new ones and set your units in BricsCAD Shape.
Start a new drawing Hit the big, blue box, with the white plus labeled "New drawing". Easy right?
Get started with BricsCAD Shape - Joachim-s Journey -new drawing-e1572273443217-1024x578
Set the units from the drop-down menu directly below this. You can only set the units in a new drawing. If you open an existing file the units of that file are used.
Get started with BricsCAD Shape - Joachim-s Journey -set units-e1572273464469-1024x579
Open an existing drawing either click one of the thumbnails (your most recently accessed files are displayed here) or click the "open drawing" button and navigate to the file.
Get started with BricsCAD Shape - Joachim-s Journey -open drawing-1024x576
Learn
The Learn tab is what you would expect from the title and more! It's a great resource whether you're completely new to BricsCAD Shape or a veteran CAD user trying to advance your skills. Here you'll find access to all BricsCAD tutorials, not just BricsCAD Shape and sample projects to get you started.
Get started with BricsCAD Shape - Joachim-s Journey -tutorials-e1590733021481
If you need more tutorials you can learn BricsCAD Shape in less than 25 minutes in our Help Center.
Where next?
I hope you enjoyed your first glimpse of BricsCAD Shape. There's plenty more to come so please return for the next stop on my BricsCAD Shape Journey!
Download BricsCAD Shape Free
Watch the webinar "BricsCAD Shape in 10 minutes"
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
